VB code in Push Button
  • August 23, 2011
  • 2 replies
  • 7267 views
Hello all,
I ahve this irritating problem in VB code. I'm trying to add up to arrays of equal dimension via a push button control in MathCad (15 on Win 7) so that the output get's written only on demand to a file. But to no avail. Can't figure out what's wrong - see attached MC file.
Does anybody know enough of the BV in Mathcad to help?
Raiko
Which summation are you trying to achieve?
Mike
Raiko17-PeridotAuthor
Hi Mike,
summation in the sense that I want to extend the array by the array I'm adding up. In the example I have a column array (vector) which I'd like to extend with another vector of equal size so that the result is a two-column vector.
Cheers
Raiko
Oh, so you mean like augment?
Mike
