vendor daemon is not being read...File not found, __PTCD_PATH__
  • February 22, 2012
  • 2 replies
  • 8920 views
Hello I can not use MathCad because I have a problem with the vendor daemon it is not being read, this is what is happening...
License file(s): C:\MathCad Licence\lm_41980836.txt
(lmgrd) lmgrd tcp-port 7788
(lmgrd) Starting vendor daemons ...
(lmgrd) License server manager (lmgrd) startup failed:
(lmgrd) File not found, __PTCD_PATH__
(lmgrd) File not found, ptc_d.exe
So where I can find _PTCD_PATH_ and ptc_d.exe,I think the route is not good
Vendor daemon status (on ISSAC):
ptc_d: The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Vendor:Host: ISSAC
License path: 7788@ISSAC;
FLEXnet Licensing error:-97,121
For further information, refer to the FLEXnet Licensing documentation,
available at "www.macrovision.com".
Please is very important to install MathCad
Best answer by VladimirN
In your license file you must have the following lines:
Hello!
What version of Mathcad are you using? And please attach to the message your license file.
VladimirN24-Ruby IVAnswer
