11-Garnet
Aug 19, 2026 8:41 PM UTC
What is the best AI model to deal with Mathcad questions?
I am a fun of Mathcad (the classic version in my case), but far from being an expert. So sometimes I come here, but recently I often use AI chats to query for basic help.
I found that ChatGPT and Claude (free plans) are probably the most responsive models in my case. But they tend to not follow always my prompts that I am still using MC11.2 old version.
But there are many other AI models around.
So I would be curious to know what kind of AI models new and experienced users here prefer - if they use them at all.
Thanks.
Aug 19, 2026 9:07 PM UTC
I don't use AI when it comes to Mathcad (and, for that matter, rarely use it in other situations either).
We’ve repeatedly had questions here on the forum from users who wanted an AI to generate a Mathcad worksheet for them, and the results were consistently terrible and unusable.
Even when it comes to mathematical questions, the answers of the AI’s are often incorrect and, when followed up on, can be contradictory. But in both cases, the models will continue to make progress and improve (sometimes at an alarmingly rapid pace).
However, Mathcad is a niche product with an apparently declining user base, and that will likely also affect the pace of development for AI models related to Mathcad questions.
But as I said, due to a lack of personal experience, I can’t recommend any specific model.
11-Garnet
Aug 19, 2026 9:20 PM UTC
Thanks ​@Werner_E .  I share the perplexity (term that overlaps one of the many models) of asking them mcd files. I use only the prompts just to ask specific questions on “how to”.
An idea that  came to my mind and that I will probably implement is to use NotebookLM model to upload in a “notebook” all  the mathcad ebooks that I collected over the years (above all in the first decade of 2000).  Many of them are in russian language, that I cannot understand. But NotebookLM does not have problems in mixing languages, and answering in one of your choice.
The free plan allows to uplaod up to 50 ebooks, so it seems enough. Then the model will answer one’s questions by inquiring only the sources that were uploaded.
Aug 19, 2026 9:25 PM UTC
Sounds promising. Pls share your experience here once you are done with it.
Guess the problem may be that the AI is not able to ‘read’ the Mathcad notebooks and you will have to turn it into pdf’s first. And then the notebooks probably would have to be documented verbally in great detail for the AI to be able to answer questions reliably.
Good luck!
23-Emerald V
Aug 20, 2026 5:45 PM UTC
Hi Anthony,
LLM’s like where chatgpt etc are based upon can work with natural language, and programming languages, all kinds of human readable language. I suppose NoteBookLM has similar capabilities.
Bear in mind that the file format of Mathcad 11 is unknown, unpublished, as opposed to that of Prime 11.
Mathcad 11’s .mcd files are binary files, potentially encrypted.
Prime 11 files are .zip archives containing .xml files, and more .zip files. Where .xml is similar to a programming language (human readable), the binary files of Mathcad 8 and higher are in no way (directly) understandable for humans, you need a machine to interpret the binary data and translate it to human readable stuff.
Terry Hendicott has managed to create an app that can produce Prime files, using chatgpt.
I suppose that if you want to create worksheet files that Mathcad 11 can work with, you start with the older .mcd format, as used by Mathcad 7 and before. Those are .ASCII text files, human readable.
11-Garnet
Aug 20, 2026 7:23 PM UTC
​@LucMeekes thanks for your advices. As I was saying, I am not looking to AI for miracles (I am skeptical, for instance, of the new trend of AI agents), but just as an assistant to help guide me through specific doubts.
More generally, I was aware that the classic .mcd  format of MC 11.2 is unreadable outside Mathcad itself. It is a different matter (in theory, I should add, because the practical experience may be far from ideal) for the Mathcad 15 format. Here is what ChatGPT has to say on the point:
“Can you read Mathcad 15 file format?”:
Yes—especially for Mathcad 15 .xmcd files. Mathcad 15 uses XML-based .XMCD worksheets (and compressed .XMCDZ), so I can inspect the worksheet structure, equations, variables, units, text regions.
Then I insisted: “If I ask, will you able to produce a Mathcad 15 file format?” Answer:
Yes. If you ask me to build a Mathcad 15 worksheet, I can generate an actual .xmcd file and give you a download link. I can create worksheets containing calculations, variables, units, explanatory text, and structured sections, and I can also modify an existing Mathcad 15 file you upload. The main caveat is that I don’t have Mathcad 15 itself available to open and execute the worksheet, so I can validate the XML structure and calculation logic, but final compatibility should ideally be checked once in Mathcad 15.
Final question: “Will you able to read and produce also Mathcad Prime format files?
I can read and analyze Mathcad Prime .mcdx files you upload, including extracting equations, variables, units, text regions, and worksheet structure. PTC confirms that .mcdx is the native Mathcad Prime worksheet format and that it is XML-based.
For producing new .mcdx files, I need to be more cautious than with Mathcad 15 .xmcd. I can construct or modify the underlying Prime file structure, but I cannot currently guarantee that a newly generated .mcdx will open correctly in every Mathcad Prime version, because Prime's package/schema details vary by version [...].
Undoubtedly, the AI is echoing the same complaints made by several users on this forum - from what I remember -, when newer versions of MC Prime were released.
