Why does Mathcad return a complex number instead of an integer?
  • October 26, 2011
  • 8 replies
  • 5193 views
Hi all. I have a model that calculates heat transfer coefficient. It is supposed to and does most of the time, return a numerical value (an integer) for the heat transfer coefficient. However, sometimes it will return a complex number, e.g. 20 + 5i, instead of an integer. What does i stand for in Mathcad and how can I get the model to return an integer?
Best answer by Fred_Kohlhepp
As you have surmised, i is the square root of -1, your result is complex.
Two questions:
  1. Why an integer?
  2. Can you post just the equation that results in the complex number?
Hello!
Please, attach your Mathcad worksheet.
Sorry I can't attach the Mathcad worksheet as it contains confidential information but is there any information I can give you which will help?
Need a screenshot showing the problem.
23-Emerald I
October 26, 2011
Two questions:
  1. Why an integer?
Why integer!?
It is a real value - see http://en.wikipedia.org/wiki/Heat_transfer_coefficient
23-Emerald I
October 26, 2011
I agree it should be real. But it shouldn't have to be an integer!
Somtime it can by integer, by the rounding for example
In Mathcad MM we can switch off the calculation with complex numbers.
In this case we get not a complex number but an erroe message and can trace this error
