X Y plots on MathCAD 15.0
  • February 5, 2014
  • 16 replies
  • 11452 views
Can someone explain how to plot the graphs of
y=x^4
and y^2= 24x
on the same plot to enable me to work out the enclosed area between the two curves.
Thanks in advance
Matt
Best answer by Werner_E
A variable which has been assigned a value can't be used for a quickplot.
See the attached file for some solutions.
If noone guessed I'm using MathCAD 15.0 programme
Not sure we could have guessed from your original post
Mike
Something like thjis?
Mike
How do you get that but I get this?!
I'm obviously missing something here!!
And I need the second equation to be y(sqrd)
y^2 = 24x
Have a look at the attached.
It seems you put a decimal after the y2 definition. Make sure you start the brackets immediately after the variable.
Something like the attached, guess.
Unfortunately Mathcad still does not plot implicit functions, so you have to reformulate it either explicit to x or to y.
@Mike: I think you misinterpreted the second function
Good point Werner,
I didn't want to change the formula as I wanted to show him how to graph it. Superb work by the way.
Thanks for your help.
I have got down to plotting the graphs but still am not having any luck.
Can anyone help to solve my problem?! I just need those graphs to be plotted on the same axis
Cheers
Werner_E25-Diamond IAnswer
How did you do the shading/hatching of the area between the two curves in your post above?
