Calculation of area under a curve through x,y data points
I am using Mathcad Prime 7.0 7.0.0.0
I have a curve generated using a trace that connects plotted x,y points. How can I use Mathcad to calculated the area under that curve?
    23-Emerald V
    Please attach the Prime worksheet. That will help us answer your question in the best way.
    You should also know that this part of the Mathcad/Prime forum is mainly for installation questions.
    Next time you should post here: https://community.ptc.com/t5/PTC-Mathcad/bd-p/PTCMathcad
    23-Emerald V
    This function calculates the area under the curve defined by x and y data.
    It uses the triangle rule:
    See attached Prime worksheet.
