Jan 13, 2021 11:16 PM UTC
Error "Conversion Failed, Conversion aborted.." while converting legacy Mathcad worksheet to Prime
Issue:
  • Error Conversion Failed, Conversion aborted.. while trying to convert any legacy Mathcad worksheet
  • Getting error Conversion Failed, Conversion aborted.. while trying to convert Mathcad worksheet
  • Converter crashes
Cause:
  • In-complete or issues with Mathcad Prime installation
  • Converter not registered with Windows
Resolution:
  • Uninstall and Re-install Mathcad Prime
  • Run the setup.exe using Right Mouse Button Option "Run as administrator" on Windows 7, Windows 8 and Windows 10 machines
23-Emerald V
Feb 22, 2023 9:47 PM UTC
You can add another potential cause:
The filename contains a character that the converter doesn't like, such as '#'....
(See https://community.ptc.com/t5/Mathcad/Error-Converting-file-from-version-15-to-Prime-8/m-p/857766#M205277 )
Community Moderator
Feb 23, 2023 5:54 PM UTC
Hi LucMeekes,
Yes, you are correct; I will have this message passed to our technical team and have the article updated.
Thanks for your input
Anurag
23-Emerald V
Feb 23, 2023 6:33 PM UTC
Better still, your technical team makes sure that file name characters accepted by Windows do NOT cause (such silly, unnecessary) errors in Prime and/or its converter.
