Installation fail
Good day!
After running the installation file (pim_installmgr_mathcad) and after the execution is over - nothing happens and nothing is installed.
Tried all compatibility settings and I still can't install the program.
What version of Mathcad Prime and Windows OS are you using?
Windows 11 Pro N, Version 21H2
Mathcad Express - actually don`t know what version, downloaded from the Mathcad Student Downloads
@PB_9720152,
Could you try downloading Mathcad Express from this link? - https://www.mathcad.com/en/try-and-buy/mathcad-express-free-download. See if it helps.
23-Emerald V
Did you follow the installation rules as set out here:
https://community.ptc.com/t5/Mathcad-Installation/Step-by-Step-Installation-Procedure-for-Mathcad-Prime-8-0/td-p/789358
Especially:
"execute/run pim_installmgr_mathcad.exe,  run as an Administrator."
after this step - nothing happens and nothing is installed, the window closes and that`s all.
23-Emerald V
And you DID run pim_installmgr_mathcad.exe as an administrator...?
