3-Newcomer
Mathcad Express installation failure
1. Received an email for the Mathcad Express download
2. Clicked on button, the file pim_installmgr_mathcad.exe was downloaded.
3. Run the a.m. file. Extracting... window appeared, when completed it closed and no installation happened
I have a 64-bit operating system with windows 10.  Tried to run as administrator as well.
Thank you.
VladimirNAnswer
See solutions from this article - "Mathcad Prime installer fails with status "Unsuccessful"": https://www.ptc.com/en/support/article/cs200121
Try the following tips:
1. Create a backup (or just archive) of the config file (in this directory: C:\Users\CurrentUser\AppData\Local\PTC\)
2. Delete the current config file (in this directory: C:\Users\CurrentUser\AppData\Local\PTC\)
3. Run Mathcad Prime again
mecseri3-NewcomerAuthor
3-Newcomer
Thank you Vladimir, but those solutions do not work for me. Please note, that Mathcad Prime has never been installed on this machnine. It is the installer which fails to start in my case.
Try using the installer from here: https://alfasoft.com/product/mathcad-prime-9-trial/
