XMCD Conversion/Converter - No License Error
I am attempting to convert .xmcd files, using PTC Mathcad Prime 8.0.0.0 XMCD, MCD Converter. When I attempt to make the conversion, I receive a "No License" error in the MCDX Status dialog. I just downloaded Mathcad Prime 8.0.0.0. The files are Mathcad 15, and I do not have Mathcad 15 on my computer.
VladimirNAnswer
Starting from the 7th version of Mathcad Prime you can use the built-in converter (before the installation process, it is necessary to select it among the installation components).
VladimirN24-Ruby IVAnswer
I selected that option during my installation, and the Resources -> References -> Migration Guide within Mathcad Prime 8.0.0.0 directs me to use the XMCD, MCD Converter to convert the files. Is there some other way to access them in Prime 8.0.0.0?
23-Emerald V
You are (most) probably using Prime 8 in Express mode. Quick check...Does the mean function work?
If you type
          mean(2,3=
does it show:
or does it show:
In the first case you have a licensed Prime,
In the second case you have Prime Express. Prime Express is the free incarnation of the software. It allows much, but not everything: No programming, no symbolics, no solve-blocks, no conversions and also premium features such as mean() and stdev() are not supported.
You can obtain a free license to use Prime to its full functionality for a duration of 30 days. See here: https://community.ptc.com/t5/Mathcad-Installation/How-to-Acquire-30-days-License-for-Mathcad-Prime-7-0/m-p/721613#M413  (The process for Prime 8 should be virtually the same as for Prime 7).
If you do have a licensed Prime, and the converter (still) isn't working, you should contact PTC product support.
