Mar 22, 2022 4:07 PM UTC
XMCD convertor not working
xmcd convertor not working. I mean i Cant click on it
DJNewman
DJNewmanAnswer
Mar 31, 2022 6:09 PM UTC
Is your Prime 8 in "Mathcad Express" mode (the converter won't work here) or is it a full licence (or the 30-day free trial)?
If it's a full paid-for licence, then when you were installing it, did you check the XMCD, MCD Converter at this part of the installation?
(Imagine it says Prime 8.0.0.0)
PTC Marketer for Creo and Mathcad. I run their YouTube channels, some Creo campaigns, and all Mathcad campaigns and communications.
DJNewman
Mar 22, 2022 6:06 PM UTC
What is your Mathcad Prime version?
Mar 23, 2022 9:07 AM UTC
I am using ptc mathcad 8.0 but here after downloading, I cant click on the xmcd convertor in order to convert a file. actually the file is of older version. can you or anyone please convert this file into mathcad 8.0 version. I have been trying since last month to convert it but unfirtunately cannot do it.
thanks
Mar 23, 2022 9:34 AM UTC
18-Opal
Mar 23, 2022 4:19 AM UTC
Perhaps you need mathcad 15 installed too? - Just guessing.
DJNewman
Mar 23, 2022 2:25 PM UTC
As an FYI, starting in Prime 7, you don't need Mathcad 15 installed to use the convertor. (You did for Prime 6 and prior.)
Mar 23, 2022 7:55 AM UTC
Try this solution - "Error "Conversion Failed, Conversion aborted.." while converting legacy Mathcad worksheet to Prime": https://community.ptc.com/t5/PTC-Mathcad-Installation/Error-quot-Conversion-Failed-Conversion-aborted-quot-while/m-p/707519#M50
Jun 1, 2022 9:54 AM UTC
Bro i have installed matchad 6.0.0. can you or anyone convert the attached file in matchad 6.0.0 and sent it back please? I am very worried
23-Emerald V
Jun 1, 2022 2:10 PM UTC
Here you go.
The messages from the converter are:
7-Bedrock
Mar 31, 2022 4:55 PM UTC
Hi
I am new and have the same issue. I have a MathCad15 file and need to use it in MathCAD 8 Prime.  The Converter on the IN/OUT tab is greyed out.  Is there something I need to install separately?  My files are too big to attach. Thanks for any help.
DJNewman
DJNewman19-TanzaniteAnswer
7-Bedrock
Mar 31, 2022 6:21 PM UTC
Full paid for version.  Thank you so much...Re-installed. Yes that worked.  Now i have a bunch of errors on the file I converted.  But this is a step up from where I was earlier.  I am new all around to this environment so I don't know how quickly I will work through these errors.  Thanks again.
