Error "Conversion Failed, Conversion aborted.." while converting legacy Mathcad worksheet to Prime
  • January 13, 2021
  • 4112 views
Issue:
  • Error Conversion Failed, Conversion aborted.. while trying to convert any legacy Mathcad worksheet
  • Getting error Conversion Failed, Conversion aborted.. while trying to convert Mathcad worksheet
  • Converter crashes
Cause:
  • In-complete or issues with Mathcad Prime installation
  • Converter not registered with Windows
Resolution:
  • Uninstall and Re-install Mathcad Prime
  • Run the setup.exe using Right Mouse Button Option "Run as administrator" on Windows 7, Windows 8 and Windows 10 machines
You can add another potential cause:
The filename contains a character that the converter doesn't like, such as '#'....
(See https://community.ptc.com/t5/Mathcad/Error-Converting-file-from-version-15-to-Prime-8/m-p/857766#M205277 )
Community Moderator
February 23, 2023
Hi LucMeekes,
Yes, you are correct; I will have this message passed to our technical team and have the article updated.
Thanks for your input
Anurag
Better still, your technical team makes sure that file name characters accepted by Windows do NOT cause (such silly, unnecessary) errors in Prime and/or its converter.
