Sep 25, 2024 6:58 AM UTC
Cabling: changing location sequence
Is there a way to reorder the sequence of locations within a network? Pushing them up or down in the primary defined sequence you might need to reconsider in the course of your design?
Additionally, I would like to know if it's possible to remove a location within a routed wire/cable without it being deleted in the network itself.
Emeritus
Sep 27, 2024 6:50 AM UTC
Hi @DV_6069025,
Thank you for your question.
Vivek N
Community Moderation Team.
Nov 5, 2024 3:40 PM UTC
Is this question related to Creo Elements Direct/Cabling or to Creo Parametric Cabling, they are two different products.
