Cabling: changing location sequence
  • September 25, 2024
  • 2 replies
  • 684 views
Is there a way to reorder the sequence of locations within a network? Pushing them up or down in the primary defined sequence you might need to reconsider in the course of your design?
Additionally, I would like to know if it's possible to remove a location within a routed wire/cable without it being deleted in the network itself.
Community Moderator
September 27, 2024
Hi @DV_6069025,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
Is this question related to Creo Elements Direct/Cabling or to Creo Parametric Cabling, they are two different products.
