2-Explorer
Show release information in Pro/E and Creo title bar
Show release information in Pro/E and Creo title bar, for example show as "Pro/ENGINEER Wildfire 5.0" instead of "Pro/ENGINEER", "Creo Parametric 2.0" instead of "Creo Parametric"
DomenicLaritz
I voted down, because in my opinion this information isn't necessary.
Hi
This is already available in the main window. The version is not shown in sub windows which I believe makes sense. Is your request about the main or sub windows?
This is for (PTC) inhouse use only. not open for users.
Case 10795067 ,
SPR 2128528,
Document CS64271.
This is a important information, when we have multiple release version of Pro / E,
Avoid the use of the incorrect release version.
Well I guess you learn something new every day. I will investigate why we do not provide the version number, in the mean time when you launch Creo the embedded browser should open to a landing page.  The landing page for each release of Creo is different.
I assume you just want release and e.g. 1.0. 2.0 etc and not the maintenance build
Thank you, this is important information, which cause us to lose a customer.
Not long ago, a customer came to our company.
He needs to use the wildfire 2.0 to modify the model, and I give him open wildire 3.0.
When he change is complete, only to find the wrong version.
Since then, we did not see his order.
If the version information to display in the title bar, this error should not occur
3-Newcomer
This functionality is very import for me too. Since the  profile of some releases is the same, this confuse us many years ago.!!
Can this be set back to Open for Voting?
Open for voting as requested
Hi Jim, do you have further information to share about this issue??
