2-Explorer
Show release information in Pro/E and Creo title bar
Show release information in Pro/E and Creo title bar, for example show as "Pro/ENGINEER Wildfire 5.0" instead of "Pro/ENGINEER", "Creo Parametric 2.0" instead of "Creo Parametric"
hi,JIM,  can add this enhancement into Creo 3.0 or not? Thanks.
Hi Jim, this enhance is not added into Creo 3.0. Is that a plan to add into Creo 4.0. I don't know why PTC would not to change it. Is it a difficult task for R&D????
Hi
It is certainly on the list to do in Creo 4.0
thanks, jim
Hi Jim, thank you for this good news. The preference way is adding release and datecode information into title bar since now we always need to select Menu File > Help > About Creo Parametric to check release and datecode information.
6-Contributor
I serious need the information because we have multiple-version of Creo Parametric ( 2.0 ~ 4.0)
So, I hope to display Creo Parametric version in title bar.
ASAP !
Since each icon is diffferent for each build of Creo you are launching, rename them to reflect the version and build.
Then educate your users to select the proper version for their customer's files. ☺
Creo Parametric 4.0 F000 only shows Creo Parametric at the top of the window.
Emeritus
