agarland
Creo View 13.0 & Creo Illustrate 13.0 have Released!
  • May 15, 2026
  • 548 views
The Visualization family of products, Creo View Clients, Creo View Adapters, Creo View Toolkits and Creo Illustrate have released. When considering updates to any of these products, it is recommended to update all Visualization products to maintain compatibility across the Enterprise.
Key Highlights
Visualization Clients:
Creo View Web 13.0
  • Simple distance and envelope measurement directly in the web UI
  • Improved annotation visibility when highlighting geometry
  • See the Creo View Web 13.0 What’s New for the complete list of feature updates
Creo View Desktop 13.0
  • Improved selection and visualization of MBD annotations and cross sections
  • Modern web-based watermark editor with future Windchill integration potential
  • Expanded ECAD visualization, including native layer color support
  • See the Creo View 13.0 What’s New for the complete list of feature updates
Creo View WebGL Toolkits 13.0
  • Measurement APIs exposed through the WebGL Toolkit for solution builders
  • Fixed graphics area for figures, eliminating resolution-dependent variations and ensuring consistent visual output across devices
  • Improved workflow for creating new figures
  • Support for callouts on assemblies
  • Pre-configurable library of in figure item lists
  • Import IsoDraw illustrations
  • Improved workflows when editing elements in 2D figures
  • Ability to directly import raster images into 3D & 2D figures
  • Ability to preserve inset views to display a different state from the main view
  • See the Creo Illustrate 13.0 What’s New for the complete list of feature updates
Creo View Adapter 13.0
  • AutoCAD adapter introduced for command line validation
    • File Synchronization not included
    • Additional file types PDF, DXF, DWG
    • Windchill-side implementation limited to testing and Windchill custom worker basis
  • Support for publishing and visualizing Creo Harness Assemblies, enabling richer representation of routing data
  • Enabled secure publishing to Windchill environments configured with SSO using OAuth authentication
  • Updates to supported MCAD and ECAD authoring tool versions to ensure compatibility with the latest releases
Support Matrices
Documentation
Download
7-Bedrock
August 11, 2026
Thanks Adrian,
For the information regarding CI 13 (What's New PDF). Could you share the corresponding PowerPoint presentation containing screenshots with us?
In particular, I would like to learn more about the "Ability to show a different state in an inset view to the main view."
Regards, Mike
