3-Newcomer
September 14, 2026
Help opening suspected Creo Schematics 2D diagrams
  • September 14, 2026
  • 2 replies
  • 64 views
Hello.
I need to identify/open/convert two legacy .dge files, believed exported from Creo Schematics in 2015/16.
I need to check what I believe will be a room layout, and update whatever is shown to create a new file (PDF, DWG, DXF) in AutoCAD.
If anyone is able to assist with this it would be appreciated - I have downloaded Creo View Express (v13) but it says the files are unsupported.
der_Wolfgang
May be you might wanna ask your question in a more matching forum like:  https://community.ptc.com/t5/Creo-and-Creo-Parametric/ct-p/creoparametric
Creo Parametric should not be confused with Creo Elements/Direct Drafting, formerly CoCreate ME10 (2D) and or ME30 (3D) CAD Products.  You posted your question in the section for Creo Elements/Direct Drafting section.. The chance of getting helpful answers is better using an appropriate forum/section.
@admins  It is a little annoying how many questions are posted in the wrong forum sections. It is a waste of time reading for those people focusing on Creo Elements/Direct.
And is is annoying for the Original Posters who don’t get an answer!
What are you planning to do to better avoid those false posting in the future?
● cad.de + osd.cad.de ● java-forum-stuttgart.de + jugs.de ● notepad-plus-plus.org ●
Catalina
Community Moderator
September 23, 2026
Hello ​@CA_14683848,
Please note that I have moved your topic to the designated Schematics/View board.
Thank you ​@der_Wolfgang for highlighting this. Please make sure to use the “Report” button, which functions the same way as “Notify Moderator” did in the past, as @admins does not tag/notify us.
Best regards,
Catalina | PTC Community Moderator
