3-Newcomer
Oct 11, 2026 7:28 AM UTC
library issue
I am using Creo Schematics Release 10.0 and Datecode10.0.0.0 getting error message wile trying to use "03_cond_unsielded_molded_DT" - Datatable "03_cond_unsielded_molded_DT" is dependent on item which is not present in internal or Central catalog Here are the errors that I faced Datatable "03_cond_unsielded_molded_DT" is dependent on item which is not present in internal or Central catalog
Emeritus
Oct 16, 2026 5:23 AM UTC
Hi ​@DB_4596772,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team.
