Rotating and translating in Creo® Illustrate 3.0
  • July 29, 2016
  • 2 replies
  • 1643 views
We have just transitioned to Creo® Illustrate 3.0 from a different package. We use Creo® Illustrate to make the technical drawings for our manuals and publications.
Oftentimes we need to rotate or translate a group of parts around the axis/centerline of another part. For example, we often need to show a hinged cover in a raised position. Or we need to show a part coming off an axle.
How do I select the parts and select the axis?
How may I do that with as much precision as is possible? I do not want to just "eyeball" the process.
Neal Lewis
agarland
I have attached a short video that shows how to use another parts coordinate system to rotate or move parts.
This will allow you to rotate a part around another parts axis, you can also use construction geometry for this.
Hope this helps. Video Link : 7146
nlewis1-VisitorAuthor
Adrian,
Thanks! A step in the right direction.
Now if I can figure out how to select all of the parts (over 77) scattered through the SBOM (consisting of several thousand parts) and keep them selected while I rotate them without accidentally deselecting them.
Here I go.
Thanks again for your help.
Neal Lewis
P.S. I am taking the PTC University training on Creo® Illustrate, but this hot project has to be done now. Neal
