Nov 24, 2023 10:58 AM UTC
Impossible to select edge and center entities in Creo View
Hello everyone,
i'm trying to take a measure in Creoview but is impossible to select the edges.
The selcection is possible only onsurfaces but i have need to take a measure from center to center(image 1).
The file output is a pvz generated from Creo illustrate or native solidworks (0457033.zip).
Is there any set to do this?
PS: I'm using Creo view MCAD
ty,Matteo
Emeritus
Nov 29, 2023 12:07 PM UTC
Hi Matteo_1987,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
Like the product and version details. It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Vivek N
Community Moderation Team
Nov 30, 2023 8:47 PM UTC
Hello  vnambooheri , attached to my question is the image of the measurement I'm trying to take (center-center) and also the solidworks file that I opened from creo view.
I'll add two more here:
In this image you can see that the centers are not displayed/proposed. The file is a Solidworks 2022 opened with Creo View 10
Edges, known points that are usually recognized with these files cannot be seen or selected. I can select only surfaces.
In this last image, however, the normal result of a selection showing known edges and points including the center taken from a Creo Parametric object also opened with Creo View.
Matteo.
