Nov 12, 2024 3:01 PM UTC
Selecting blocks in Creo View in a dwg file
We have P&IDs drawn as dwg files.  Each object on P&ID is a block with attributes and corresponds to a part in Windchill.  Our users view the dwgs in Creo View.
I want to be able to select on a block in CV and have the user see the attributes and go to the website embedded as one of those attributes.
Right now, when I click on a block in CV, it doesn't select the block.  It selects the individual lines of the block and I can't see the block attributes anywhere.
Does anyone have any ideas to make this work or what could be used to provide "smart schematics" to the users?  It should remain dwg based.
thanks
Emeritus
Nov 18, 2024 3:50 AM UTC
Hi @kmccormack-2,
Thank you for your question.
Your post has not yet received any response. Please feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team.
Nov 18, 2024 2:12 PM UTC
Here's a screenshot
