Tables In Creo View Express
Hi
I have recently installed Creo 11 and been able to make tables in MBD.  I would like to be able to see these tables and other annotations in Creo View Express
I export the Creo model with the tables and other annotations to pvz format and expect to see the tables but they aren't there.  I can see dimensions with GD&T callouts so I am assuming my recipe file (attached) is ok.  I did some digging and found that maybe I need the Creo View adaptor 11.1.0.0?  Do I even need the Creo View adaptor if I am manually creating the PVZ file using Save As from Creo 11?
Support_for_Table_Annotations_for_Creo_Parametric
I thought maybe my version of Creo View Express was the issue so I went to the Creo View Express download page here and even though it says Creo 11.1. it downloads 11.0.0.  I installed that and loaded my pvz file and still no tables being displayed.
I used a recipe file as attached.  I had to change the rcp extension to txt, it wouldn't accept rcp.
My questions are;
- Is my Creo 11.0.0.0 producing a pvz file that could show tables if the Creo View Express viewer was version 11.1?
- Is there anything else I can do to achieve the desired functionality of viewing annotation tables in Creo View Express?
TIA
Derek
vdegaonkar
Save As PVZ from Creo Parametric shall support from Creo Parametric 11.0.4.0 onwards.
If you are publishing with Creo view Adapters (Interactive/Worker) then you shall be atleast on Creo Parametric 11.0.2 or later.
Creo View Express 11.1 should be able to view table annotations.
vdegaonkar
HI @Derek_Jefferson
Apologies for inconvenience caused in regards with Creo View Express 11.1 download. It was technical glitch caused the problem.
We have addressed the problem and now you should be able to download Creo View Express 11.1 from ptc.com page.
-Varad
Emeritus
Hello @DJ_01_10423714,
It looks like you have some responses on your topic. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Hi Vivek
The issue, for me at least, has not been solved as yet.
My issue is specific to me wanting to create pvz files from Creo using 'Save As'.  After speaking with my local reseller and their communication with PTC, my understanding is that Creo 11 up to 11.0.3.0 is bundled with Creo View Adaptor 11.0 and 11.1 is what is required which will be bundled with 11.0.4.0.
Users running worker agents may be able to see the tables if they are using Creo View Express 11.1 and the Creo View Adaptor 11.1.  I'm not 100% sure on this, best to talk to your local reseller if you have an issue publishing MBD tables.
I will respond to this thread once 11.0.4.0 is released and I can test accordingly.
Kind Regards
Derek
