Tables In Creo View Express
- 4 replies
- 1234 views
- Translate All
Hi
I have recently installed Creo 11 and been able to make tables in MBD. I would like to be able to see these tables and other annotations in Creo View Express
I export the Creo model with the tables and other annotations to pvz format and expect to see the tables but they aren't there. I can see dimensions with GD&T callouts so I am assuming my recipe file (attached) is ok. I did some digging and found that maybe I need the Creo View adaptor 11.1.0.0? Do I even need the Creo View adaptor if I am manually creating the PVZ file using Save As from Creo 11?
Support_for_Table_Annotations_for_Creo_Parametric
I thought maybe my version of Creo View Express was the issue so I went to the Creo View Express download page here and even though it says Creo 11.1. it downloads 11.0.0. I installed that and loaded my pvz file and still no tables being displayed.
I used a recipe file as attached. I had to change the rcp extension to txt, it wouldn't accept rcp.
My questions are;
- Is my Creo 11.0.0.0 producing a pvz file that could show tables if the Creo View Express viewer was version 11.1?
- Is there anything else I can do to achieve the desired functionality of viewing annotation tables in Creo View Express?
TIA
Derek
