Creo 2.0 Keyboard shortcuts anyone?
I thougt about asking a specific question about creo 2.0 keyboard shortcuts and decided to make it a sharing opportunity.
anyone wants to share his favourite most usefull keyboard shortcuts while working with creo ?
I like
Ctrl +G to regenerate.
Center click for Done
anyone knows a shortcut for normal view/ isometric view?
    November 10, 2012
    If you type "map" into the Command Finder (upper-right), you can start the Mapkeys dialog box and create your own shortcuts. Engineers typically create mapkeys to automate common repetitive tasks.
    For example, when working with large assemblies I often use "zz" to make the clicks Set Representation to> Exlude. I can select a part in my assembly, press zz and the part is excluded from the representation.
    i just descovered some more shortcuts
    ctrl + n - new file
    ctrl+d - dimetric view.
    Adam, i tried mapping keys but for some reason its not wirking - is there a short tutorial on how to do this right?
    what if i want to override an existing shortcut, will it allow it?
    Here are the default shortcut keys as defined in Creo Help.
    ALT
    • Disables filters temporarily during selection when the pointer is in the graphics window. Hold down the ALT key during selection.
    • Activates KeyTips on the Ribbon when you point to the Ribbon and hold down the ALT key.
    CTRL
    Temporarily hides the Live Toolbar in 3D part and assembly modes.
    CTRL+A
    Activates a window.
    CTRL+C
    Copies the selection to the clipboard.
    CTRL+D
    Displays a model in the default view.
    CTRL+N
    Opens the New dialog box.
    CTRL+O
    Opens the File Open dialog box.
    CTRL+R
    Repaints a window.
    CTRL+S
    Opens the Save Object dialog box.
    CTRL+V
    Pastes the clipboard contents to the selected location.
    CTRL+Y
    Performs a single-step redo operation.
    CTRL+Z
    Performs a single-step undo operation.
    ESC
    Performs one of the following operations depending on the modeling context:
    • Cancels an operation.
    • Clears the selection in the graphics window.
    • Cancels a dragger operation.
    • Closes the Live Toolbar.
    • Cancels the currently active tool.
    ENTER
    Accepts the changes and closes the Live Toolbar in 3D and assembly modes. Also clears the selection in the graphics window.
    F1
    Opens Help for the current context.
    G
    Hides the current guide for the geometry in 2D mode.
    L
    Locks or unlocks the current guide in 2D mode.
    P
    Shows or hides temporarily the precision panels in 2D mode.
    S
    Switches between the Line and Arc Creation modes in 2D mode.
    TAB
    Prehighlights a set of surfaces on an active part using shape-selection rules based on the currently prehighlighted surface. Refer to the Creo Parametric Flexible Modeling Help for more information on shape-selection rules.
    in daily use are
    A1, A2, A3 & A4 for printing.
    dxf, pdf & dwg to ouput files to local server.
    NF & NB to set model view front or back as require.
    BOM to create BOM table.
    Find the tasks that you do regularly & need a few clicks to complete, then save yourself time with a shortcut (mapkey).
