Mar 13, 2018 12:17 AM UTC
Creo 4.0 Student Edition License says "Success!" but also "Invalid file or format"
Hi, the problem is as the title states. I saw another post explaining the same problem but with Creo 3.0. I'm trying to download Creo 4.0 but it's giving me an invalid file or format when trying to install license. Tried opening the file but was empty. How do I solve this? Thanks
Mar 13, 2018 5:17 AM UTC
Having the same issue
Mar 13, 2018 5:59 AM UTC
see my reply from 2018-02-27 01:43 PM in https://community.ptc.com/t5/PTC-Academic-Program-Discussions/Licence-Issue/m-p/536850
I guess the problem is related to non-supported network card.
Please open Command Prompt window, launch ipconfig /all > ip.txt command and upload ip.txt file. I will check your ip.txt file and suggest you to disable suspicious network card.
Apr 7, 2018 9:38 PM UTC
I have the same problem
Apr 30, 2020 1:28 PM UTC
I have the save issue, if you could help, I would be thanksful
Apr 30, 2020 1:55 PM UTC
Could you please give us more information?
Product code used, first install or relicense, name of the zip file downloaded...
Alex
Aug 4, 2020 7:01 AM UTC
Creo 6.0 Student Edition License says "Success!" but also "Invalid file or format
and my ip file is here
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-0VLRRSU
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : 80-CE-62-D4-16-21
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 1:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 82-C5-F2-32-87-63
Wireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 80-C5-F2-32-87-63
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Realtek RTL8723DE 802.11b/g/n PCIe Adapter
ALSO attach my license file thats no working after reset this pc
please help me how to manage this.
Aug 4, 2020 7:08 AM UTC
LICENCE FILE
#License Pack for Session ID 4767155
# PTC License Pack
#License codes for PTC Product.
#Cpu 80-C5-F2-32-87-63
#Contact : MAHESH KATARIYA
#Address :
#Email : maheshkatariya2000@gmail.com
######### Creo Student Edition Standard #########
#Feature Line Type = INCREMENT
#Feature Name = CREOPMA_Student6
#Feature Version = 37.0
#Version = Creo 6.0
#Number of Copies = uncounted locked license
#Supercede = Y
#Issue Date = 29-JUL-2020
#Expiration Date = 30-JUL-2021
#Node Locked Option = NOTEBOOK
#Node Locked Option = ASSEMBLY
#Node Locked Option = FEATURE
#Node Locked Option = DETAIL
#Node Locked Option = INTERFACE
#Node Locked Option = WLO
#Node Locked Option = SURFACE
#Node Locked Option = PLOT
#Node Locked Option = CABLING
#Node Locked Option = REPORT
#Node Locked Option = PIPING
#Node Locked Option = INTERFACE for STEP
#Node Locked Option = PHOTORENDER
#Node Locked Option = Student
#Node Locked Option = SHEETMETAL-DESIGN
#Node Locked Option = Mechanism Design License
#Node Locked Option = Behavioral Modeling License
#Node Locked Option = Import Data Doctor
#Node Locked Option = Design Animation
#Node Locked Option = Language Option - CHINESE
#Node Locked Option = Interactive Surface Design Extension Module
#Node Locked Option = Mechanism_Dynamics
#Node Locked Option = Advanced Rendering Extension 2
#Node Locked Option = Creo Freestyle Design
#Node Locked Option = Creo Flexible Modeling
#Node Locked Option = Creo Unite
#Node Locked Option = Mold Analysis Lite
#Node Locked Option = GDT Advisor
#Node Locked Option = Creo Render Studio
#Node Locked Option = Additive Manufacturing
INCREMENT CREOPMA_Student6 ptc_d 37.0 30-jul-2021 uncounted \
A08090D09D01CBE300A7 VENDOR_STRING="VSVER=2.0 \
LO=(0,6,7,10,17,19,32,34,48,51,61,69,73,110,115,127,128,135,137,155,188,191,283,325,326,336,347,354,357,361)" \
HOSTID=PTC_HOSTID=80-C5-F2-32-87-63 SUPERSEDE \
ISSUER=PTC-WEB-CREOSTUDENT6 ISSUED=29-JUL-2020 \
NOTICE="maheshkatariya2000@gmail.com, " SIGN2="1D7A \
E050 2F99 A897 702B 2573 5A71 57B2 6876 6EA4 F72D \
60E7 18A2 0F74 63AC 1BCB C42E 35BD EC94 4DA5 DB56 \
E593 7904 D4ED 31B3 E5E4 E7DD 6A69 CA4F 536C"
######### Creo Direct Modeling Education (Student) #########
#Feature Name = CREODMA_Student3
#Version = Creo 6.0
#Supercede = Y
#Node Locked Option = Pro/ASSEMBLY
#Node Locked Option = Pro/FEATURE
#Node Locked Option = Pro/INTERFACE
#Node Locked Option = Pro/SURFACE
#Node Locked Option = Pro/INTERFACE for STEP
#Node Locked Option = Language Option - CHINESE Educational
INCREMENT CREODMA_Student3 ptc_d 37.0 30-jul-2021 uncounted \
70F07060F16146453951 VENDOR_STRING="VSVER=2.0 \
LO=(6,7,17,19,32,69,110,155,326,336)" \
NOTICE="maheshkatariya2000@gmail.com, " SIGN2="19D7 \
8674 EE1E 7DD9 A5EB D7ED D2E3 5E79 EC70 A3A6 983A \
01FE 585B 80E2 71E1 11F2 49CB CE0C 5FE8 1188 EBF4 \
233E 05D8 2719 5F42 A506 ABB6 CD1E BB4C 0A5F"
######### Creo Layout Student #########
#Feature Name = CREOLAY_Student3
#Version = Creo 6.0
#Supercede = Y
#Node Locked Option = Creo Layout Module
INCREMENT CREOLAY_Student3 ptc_d 37.0 30-jul-2021 uncounted \
00B060F09C007E7424F8 VENDOR_STRING="VSVER=2.0 \
LO=(6,7,17,19,32,69,110,291,326,336)" \
NOTICE="maheshkatariya2000@gmail.com, " SIGN2="04C7 \
2B4A FC19 57C9 AAE5 DAA3 B666 86DF FEB0 1DC6 26CB \
F99D D353 00E1 D3D0 1334 D99A D8A6 8B6D A86E 49B0 \
775C 8823 1839 7D82 DFBC 8A4F 89BB E441 202B"
######### Creo Illustrate Standard #########
#Feature Name = CREOILLUS_STANDARD
#Feature Version = 6.0
#Version = Creo 6.0
#Supercede = Y
INCREMENT CREOILLUS_STANDARD ptc_d 6.0 30-jul-2021 \
uncounted C0905010038A9ABC0EB1 \
VENDOR_STRING="VSVER=2.0 LO=(19)" \
NOTICE="maheshkatariya2000@gmail.com, " SIGN2="0278 \
3254 3807 3817 C7EA 1311 318A 173C C885 F76B FDCD \
737A 46E0 479A C387 1802 0FA1 D572 DD04 D91B 66F4 \
7BDC 4E31 407F 39E8 3011 7EDD A4CF DFE6 E971"
