Creo won't run!!!
Hi there!
When I attempt to open the program up, it fails to run b/c it states that it could not run the Quality Agent and if I call tech support to report an error 6. I thought tech support was open 24 hours but no joy on that. Any ideas, or should I just try in the morning? Thank you!!
    Try disabling quality agent reports during instalation of Creo and after you are done with the instalation uninstall only the PTC quality agent from your system.
    vortiz1-VisitorAuthor
    Thanks for the help. I did that however when I start creo up again I get another message dialog box. Look at the attached pic. Thanks again for the help.
    I have the same issue as this, has anyone found a fix?
    Mark,
    Sorry you're having the problem. I have seen this one time in the past and I was able to fix it by
    using the Windows Control Panel to uninstall the Quality Agent and then reinstalling Creo using (using C:\Program Files\PTC\Creo 1.0\Parametric\bin\ptcsetup.bat).
    Note that I did not recopy files, re-license or configure, I just stepped though the install so that the Quality Agent would be reinstalled and connected.
    Please let us know if this helps.
    Adam
    I tried what you suggested and it didnt work for me. I have however now got it working.
    All I did was a complete re-install, I had already tried doing this before I began looking for help but it didnt work. All I changed this time around was I let the install manager pick the install directory. With my initial install I had changed it to a different HDD not the one my OS is installed on (which was what the install manager wanted to put it in). Everything ran first go with the new install on C: and I'm currently using Creo.
    I can't see why using a different partition/HDD on the same machine would have caused this issue (thats if it was infact the issue), maybe its something that was completely random and I just got lucky on this re-install. Maybe its something for the Creo Dev's to look into?
    Thanks for the suggestion and help Adam, reading that and seeing the C:\Program Files is probably what made me think to just let it install where ever it wanted and see if it works.
    I had the same issue, but it appears I found a fix. First, I uninstalled the Quality Agent using "Uninstall a program" under the control panel. Next, I searched C:\Program Files\PTC for "Quality." I found two results. The important one was qualityagent_32_64.msi under C:\Program Files\PTC\Creo 1.0\Common Files\M030\install\addon. Opening this file allows you to install the Quality Agent again. After doing this, the program worked for me. I hope this helps.
    18-Opal
    March 14, 2012
    Hi James,
    Thank you for the reply. That is a work around for the issue. We are investigating the error and will be addressing this in the next maintenance release of Creo 1.0. Thank you for your diligence in finding the above mentioned procedure.
    Procedures:
    1) Uninstall Quality Agent from the Add/Remove Programs in the control panel
    2) Install qualityagent_32_64.msi from C:\Program Files\PTC\Creo 1.0\Common Files\M030\install\addon
    3) Start Creo 1.0 Parametric
    Mark
    Hi Mark,
    I tried the method you suggested and still got an error. Here's a creen recording of the method. Let me know if I made any errors in following your directions. One thing I did notice was that in your instructions it states to go to M030 but all I had was M020. Is that maybe the issue that is causing all of this. Thanks for your help. Oh by the way. the video is less than 2 minutes plus you can fast forward thru it if you like. Thanks again and have a great day!! Video Link : 2672
    Vic
    Hi all,
    I installed Creo schools edition today and encounted the exact same issues as Victor, my install folder is also M020 rather than M030 as described in the previous post. I will be following this thread closely I hope a fix is available.
    Matt
    18-Opal
    April 3, 2012
    Hi Matthew,
    I am working with Victor to diagnose the issue. BTW.....do you have a anti virus tool running?
    Which is it?
    Once you start Creo and you get the error message, can you open Start > Control Panel > Administration Tools > Event Viewer. Click Windows logs and applications. Do you see any red errors? Can you send me the information to -?
    Mark
    I have the same EXACT problem and its annoying me cause i have a project due in creo and cant get it past quality agent! need help plz. i have already tired the suggested soluions mentioned before and still doesn't work. mine says M020\install\addon instead of M030 as well.
    18-Opal
    April 18, 2012
    Hi all,
    PTC Development is still diagnosing the issue and have pinpointed the problem. Once confirmed, we will provide a fix for the experienced issue.
    Thank you for your understanding. Once available, I will post the solution.
    Mark
    I am having the same problem. Mine showed error 6. Hence, I uninstalled Quality Agent and the reinstalled from C:\Program Files\PTC\Creo 1.0\Common Files\M030\install\addon. However when I startes Creo again, it still shows the same error code 6. Any solutions so far? Do you think going to the local PTC office here in Malaysia would help?
    Sivaroopan
    I also had that error, 6 or 8 depending on different things I tried. After reading these posts I found a possible cause and a simple(?) solution.
    I'm running Win7 and
    Creo was installed by default in the folder Program Files.
    Quality agent was by default installed in the folder Program Files (x86).
    I uninstalled Quality Agent and then reinstalled it ( from C:\Program Files\PTC\Creo 1.0\Common Files\M030\install\addon) in the folder Program Files (same as Creo installation) and now it works fine.
    Good luck to anyone with the same problem!
    /Christian
    18-Opal
    June 14, 2012
    Thank you Christian for the workaround.
    BTW......we will be releasing Creo 2.0 Student Edition (formerly the free Schools Edition) in a weeks time. Once available you will be able to register for it from www.ptc.com/go/creoforstudents. Both releases can be installed on the same machine.
    Mark
    Hi folks,
    I installed Creo 2.0 Schools Edition and get an error regarding the qualityagent. After the error message Creo shuts down (dead end). I have done all steps in the blog: no success. I send you my error log.
    Protokollname: Application
    Quelle: Application Error
    Datum: 20.07.2012 18:54:12
    Ereignis-ID: 1000
    Aufgabenkategorie:(100)
    Ebene: Fehler
    Schlüsselwörter:Klassisch
    Benutzer: Nicht zutreffend
    Computer: Nextengine-PC
    Beschreibung:
    Name der fehlerhaften Anwendung: creoagent.exe, Version: 30.0.2012.130, Zeitstempel: 0x4fbc3c2e
    Name des fehlerhaften Moduls: KERNELBASE.dll, Version: 6.1.7601.17651, Zeitstempel: 0x4e211319
    Ausnahmecode: 0xe0434f4d
    Fehleroffset: 0x0000b9bc
    ID des fehlerhaften Prozesses: 0x%9
    Startzeit der fehlerhaften Anwendung: 0x%10
    Pfad der fehlerhaften Anwendung: %11
    Pfad des fehlerhaften Moduls: %12
    Berichtskennung: %13
    Ereignis-XML:
    <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
    <System>
    <Provider Name="Application Error" />
    <EventID Qualifiers="0">1000</EventID>
    <Level>2</Level>
    <Task>100</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2012-07-20T16:54:12.000000000Z" />
    <EventRecordID>3259</EventRecordID>
    <Channel>Application</Channel>
    <Computer>Nextengine-PC</Computer>
    <Security />
    </System>
    <EventData>
    <Data>creoagent.exe</Data>
    <Data>30.0.2012.130</Data>
    <Data>4fbc3c2e</Data>
    <Data>KERNELBASE.dll</Data>
    <Data>6.1.7601.17651</Data>
    <Data>4e211319</Data>
    <Data>e0434f4d</Data>
    <Data>0000b9bc</Data>
    </EventData>
    </Event>
    I am looking for an answer to start CREO 2.0. Thanks for your support.
    Andreas from Berlin (Germany)
    Andreas,
    Have you tried opening permissions and reinstalling the Quality Agent as suggested above?
    There is an issue with Quality Agent where if Creo is not installed by the same user who run Creo for the first time Quality Agent will not install because of a permissions issue.
    If the software was installed using another user name, try running Creo using that user name. You may have to reinstall it as admin with that same user running it for the first time.
    ** Just be sure to save the license before removing Creo.
    Adam
    there is only one user and only one account. I have installed & reinstalled in all orders. I have givenacces to the folders by using everyone has all rights. Therefore I have no clue whats going on. I will not reinstall windows 7 to ust to get CREO 2.0 running. I am pleading for help.
    Andreas
    I have similar issue. I cannto fix it by any of your ideas. Please, help, I need Creo for my Univeristy project. I am using Windows 8 (but I have not any compatibility issue with other programs so I do not think it is Win8 issue), my laptop has Dual-Core 2.1 GHz processor and 4 GB RAM, also graphics ATI Mobility Radeon HD 4570. I did not found any Windows Alerts in its history. I add a screen capture while Creo crashes. Please help!
    I found a solution - run CREO in administrator mode. To do that, you go into your start menu, go to the program, right click, and select 'run as administrator.'
    Hy..!!
    am hvng the same problem. It just says the same error about Quality Agent, Please Reply asap b/c am headed for practicals now. Please do connect to my PC if needed. I tried all the ways that u have mentioned above.
    Am usng
    PTC Creo 2.0 Student Edition
    submit your host id to get your license emailed to you. this problem occurs when we get our license online after entering our login id and password.
    my host id is 18-03-73-56-D7-2D
    my mail is -
    kindly send soon..and also tel me the steps to be followed
    Thanks in advanz..
