3-Newcomer
May 6, 2026 9:22 AM UTC
installation license problem: invalid file or format
I’m trying to install Creo Parametric with a student license, but while the code I was given generates a Success, the installation tool doesn’t recognize the license created and gives the error “invalid file or format”. I checked the .dat file created with the Notepad app, and it’s indeed empty. I haven’t received a mail with the license, as other threads suggest, so don’t really know what to do
3-Newcomer
May 6, 2026 12:19 PM UTC
Same issue
May 6, 2026 3:46 PM UTC
same..
May 7, 2026 9:25 AM UTC
3-Newcomer
May 7, 2026 12:00 PM UTC
The problem is the .dat file is empty, nothing to change here, is it some sort of server error?
3-Newcomer
May 8, 2026 7:22 AM UTC
Seems like it, and its the same when trying to install any version of CREO right now.
May 8, 2026 6:33 PM UTC
I believe it's a general server issue, because it's unable to generate the license. I tested both Creo 11 and Creo 12, and both reported the same problem. Initially, I thought it was the educational license, so I also tested another license, but the error persists.
May 12, 2026 4:41 AM UTC
I'm also getting an empty license file.
When I contacted PTC support, they said student versions aren't supported.
That's true, but this isn't something the user can fix.
Please help!
May 12, 2026 7:27 PM UTC
Been trying for a few days now and exactly the same problem. Empty license file.
May 13, 2026 6:15 PM UTC
I think it's back to normal. I tested it on three machines and it worked correctly, so I believe the problem has been resolved.
May 14, 2026 1:00 AM UTC
That's nice.
I was also able to obtain the correct license file.
This should reduce inquiries from students.
Catalina
Community Manager
May 14, 2026 1:39 PM UTC
Hi ​@GD_14578630
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Best regards,
Catalina
PTC Community Moderator
Catalina | PTC Community Manager
May 14, 2026 1:40 PM UTC
Tried it and still does not work for me.
May 16, 2026 1:48 PM UTC
Works now
