MarcoTosin
May 21, 2026 8:18 AM UTC
Since yesterday, the support articles have been intermittently unavailable.
Below is the message that appears:
Sorry, the article viewer is currently unavailable. Please try again later.
PeterCaseAnswer
Community Manager
May 29, 2026 11:05 AM UTC
Hi ​@MarcoTosin and ​@RandyJones,
Thanks for raising this to our attention.
We’re aware of this intermittent issue and over the past week, our team has been working closely with our CRM vendor after identifying some performance degradation and connectivity issues.
As part of the efforts, we made an API version update to several applications yesterday, including the service used by the article viewer with encouraging results. We’ll be extending this change across the remaining applications and closely monitoring behavior over the next 1–2 weeks.
In parallel, we’re continuing work to improve the resilience of our CRM integration, in particular to better handle any non-200 responses from the backend.
Since yesterday’s update we’re no longer seeing handshake errors for the Article Viewer, which would lead to the “Article ** not found” error above. Please let us know if you still encounter any problems.
We appreciate your patience while we continue to work through this.
Peter.
20-Turquoise
May 22, 2026 2:42 PM UTC
I am getting the almost the same thing today.
Sorry. Article XXXXXXX was not found. Here are some options:
MarcoTosin
May 26, 2026 2:24 PM UTC
​@PeterCase
You probably didn't see this discussion because the notifications on the new site are having some issues.
Has the problem been identified and fixed?
Thank you
Marco
PeterCaseCommunity ManagerAnswer
Community Manager
Peter.
MarcoTosin
May 29, 2026 11:40 AM UTC
Hi ​@PeterCase,
thank you for the update and for all your hard work.
Marco
