TomU
Jul 25, 2016 5:50 PM UTC
Windchill Performance Advisor - Support Lacking
Normally when I create technical support cases the response time is very good.  The case will quickly get assigned to a technician and I will typically get a phone call (or email) within a couple of hours.  I'm having the exact opposite experience with the "Windchill Performance Advisor" product area.  It's almost like there is no one assigned to monitor cases created for this product.
Most recent example:
  • Case created on July 12th
  • Realized on July 15th that no one had contacted me or even been assigned to the case yet so I escalated it.  Almost immediately I received a call from a manager promising that a tech would contact me on the next business day.  He then asked if I could de-escalate the case, which I did.
  • July 25th (today) - The case still hasn't been assigned to anyone and I'm still waiting for the first contact.
I'm also noticing that this "product" isn't listed in the All Products list when filtering existing cases.  Not under "Performance Advisor" and not under "Windchill ..."
Is there something going on with this area of technical support?  Should I NOT be creating cases under this area?
MarcoTosin
Jul 26, 2016 6:58 AM UTC
Tom,
I've been able to apply filter only in "Cases opened by my Company" tab, using Windchill PDMLink.
"Cases opened by myself" doesn't work.
Marco
TomU
TomU23-Emerald IVAuthor
Jul 26, 2016 12:17 PM UTC
Yeah, that doesn't help me.  I'm the only one in my company that opens cases.  (Currently at 350 over the last 4-1/2 years.)
Emeritus
Jul 26, 2016 12:45 PM UTC
Good day Tom,
I have been in contact with the Windchill team:
1.  Your case is in hand
2.  You will be getting contacted shortly
Best,
Toby
Jul 26, 2016 4:57 PM UTC
Tom,
Thanks for reaching out to us. I'm sorry you're experiencing those delays. I've contacted the team in charge of the PA support to make sure they get back to you and I am looking into the issue regarding the missing value in the product drop down list.
TomU
Jul 27, 2016 2:35 PM UTC
Still waiting...
Two of my cases still haven't been assigned to a support technician.  One was opened in May and one was opened two weeks ago.
Again, these aren't huge critical issues, so I don't need a call back the same hour or even the same day, but I shouldn't have to wait weeks or months.  The response time for this technical area just seems very poor compared to what I normally experience with other areas.
Without revealing too much "behind the curtain", can you explain how cases get assigned?
TomU
Jul 27, 2016 2:48 PM UTC
Wouldn't you know.  I hit the "Add Reply" key and PTC techs start calling...
Jul 27, 2016 8:30 AM UTC
Tom,
I looked into the "missing Windchill Performance Advisor" value in our web tools, and the reason it's not there is that the Performance Advisors are considered as features of the Products (Creo Parametric, WIndchill PDMLink...) and not product themselves. As a consequence, they are listed in the "Technical Area" field of the tools when this field exists (Case logger, search filter...)
MarcoTosin
Jul 27, 2016 12:48 PM UTC
Pierre,
I'm not trying to take shortcuts, but I would like to take advantage of this discussion to make you aware that, since last October, I opened two calls to TS because not all Creo sessions are loaded in my Performance Advisor for Creo dashboard.
Below link to calls and a picture showing how sessions in my dashboard are vanishing.
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=12799022
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=12837883
Before Liveworx one of yours PM told me that, after this event, in which would be presented the new gadget on the use of features, R&D would resume work on open calls.
I think that, before developing new features, it would be better, at least, to fix the existing ones, especially if data aren't loaded into a system that analyze this data to take corrective actions.
As you can see we switch from Creo 2 M160 to M210 (after I read a couple of recommendations), so I believe in this tool, but it's hard to use it if data are loaded randomly.
This change has led to a crash reduction and to an increase of the MTTX time, but it is also evident a drastic reduction in the number of loaded sessions (for many users two months are passed without new loaded sessions).
Marco
TomU
Jul 27, 2016 1:21 PM UTC
Marco Tosin‌, not a hijack at all.  That's the point of this discussion.  There seems to be a bit of a hole in tech support coverage for the performance advisor area.
