Emeritus
PTC Community Monthly Stand-Out July 2023
See the Top Community Engagers and the Top Noteworthy posts for the month of July.
Top July 2023 Community Engagers:
@WernerE @avillanueva @HelesicPetr @MartinHanak @ttokoro @jbailey @LucMeekes @IbrahimTayyab @terryhendicott @Cornel @tbraxton @StephenW @Velkumar @fahmed-2 @kdirth @d_graham @Amirtharaj_K @KenFarley @MW_10727886 @Dale_Rosema
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for July 2023!  See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: RP_10384451 asked about PTC Creo parametric Bom. Solution was provided by @MartinHanak
@Lars_F
https://community.ptc.com/t5/3D-Part-Assembly-Design/PTC-Creo-parametric-Bom/m-p/889703#M130229
2. Creo:  CR_9888056 received an accepted solution from Kotom-Eng for topic UDF - Gripes.
https://community.ptc.com/t5/3D-Part-Assembly-Design/UDF-Gripes/m-p/890106#M130268
3. Creo: Thank you @YaroslavSinfor providing an accepted solution for MORECREO on this topic Configurations To Help Show Operation.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Configurations-To-Help-Show-Operation/m-p/890397#M130261
4. Creo:  ptc-2170706 needed help with this topic - When I create a drawing, the lines that should not be visible behind the thin parts are displayed. and offered him an accepted solution.
https://community.ptc.com/t5/System-Administration/When-I-create-a-drawing-the-lines-that-should-not-be-visible/m-p/885498#M29831
5. Creo: A question about Convert radii and diameters to a dimension when exporting mi to dwg
was posted by JH_10142022 and an Accepted Solution was provided by Kotom-Eng
https://community.ptc.com/t5/Drafting/Convert-radii-and-diameters-to-a-dimension-when-exporting-mi-to/m-p/886723#M1205
6. ThingWorx: Arun_C@TonyZhang gave an Accepted Solution to JiabaoXiao for the topic How do I align the internal mashup of a collection widget to the right
https://community.ptc.com/t5/ThingWorx-Developers/How-do-I-align-the-internal-mashup-of-a-collection-widget-to-the/m-p/889552#M63227
7. ThingWorx: The topic how to apply custom css on textfield textarea background-color.
 posted by Hrishab108 received an accepted solution provided by Velkumar
https://community.ptc.com/t5/ThingWorx-Developers/how-to-apply-custom-css-on-textfield-textarea-background-color/m-p/889549#M63226
8. ThingWorx: BP_9210462 provided a speedy response and Accepted Solution to the inquiry by
ParthBhadiyadra about Two way binding in java SDK
https://community.ptc.com/t5/ThingWorx-Developers/Two-way-binding-in-java-SDK/m-p/890151#M63258
9. ThingWorx: RS_10021886 asked Is there a service can get current 'Connected User' as in monitoring menu? and Velkumar provided a quick Accepted Solution.
https://community.ptc.com/t5/ThingWorx-Developers/Is-there-a-service-can-get-current-Connected-User-as-in/m-p/889554#M63228
10. ThingWorx: EB_9744252 posted the topic How to check if Job Order Notification is running? and received an Accepted Solution from mstarnaud.
https://community.ptc.com/t5/ThingWorx-Developers/How-to-check-if-Job-Order-Notification-is-running/m-p/886640#M63064
11. Vuforia: IB_10645210 posted the topic How to create breadcrumbs (contained views path)
 and received an Accepted Solution from sgreywilson.
12. Vuforia: Aditya1702 shared a post about Changing opacity in Vuforia Studio
Thank you aletenti2 for providing an Accepted Solution!
https://community.ptc.com/t5/Vuforia-Studio/Changing-opacity-in-Vuforia-Studio/td-p/890526
13. Windchill: SA_9497989 posted the topic Adding custom action on Workspace GUI
 and received an Accepted Solution by HelesicPetr
https://community.ptc.com/t5/Windchill/Adding-custom-action-on-Workspace-GUI/m-p/890602#M73475
14. Windchill: CHENAMA asked about the WT-Part Structure Visualization see which Reference Designator is assigned to which Occurence in 3D and HelesicPetr
provided the Accepted Solution.
https://community.ptc.com/t5/Windchill/WT-Part-Structure-Visualization-see-which-Reference-Designator/m-p/890547#M73471
15. Windhill: SC_8321054 about Hourly license usage report Windchill with an Acccepted Solution from
https://community.ptc.com/t5/Windchill/Hourly-license-usage-report-Windchill/m-p/889133#M73336
16. Windchill: SC_8321054 asked about Remove object from user's workspace by administrator. and  provided an Accepted Solution!
https://community.ptc.com/t5/Windchill/Remove-object-from-user-s-workspace-by-administrator/m-p/889905#M73411
17. Mathcad: JD_10737621 needed help with Fourier Series on Mathcad and  provided the Accepted Solution!
https://community.ptc.com/t5/Mathcad/Fourier-Series-on-Mathcad/m-p/887641#M207592
18. Mathcad: JW_9781974 needed with Surface plot and zero and ttokoro helped with an Accepted Solution.
https://community.ptc.com/t5/Mathcad/Surface-plot-and-zero/m-p/886584#M207508
19. Mathcad: HI_10746904 asked about the Remove specific regions from a graph
 and terryhendicott provided the Accepted Solution.
https://community.ptc.com/t5/Mathcad/Remove-specific-regions-from-a-graph/m-p/890295#M207853
