18095727\ after executing xconfmanager -pf command windchill is unable to start
  • June 30, 2026
  • 0 replies
  • 0 views
Hello Experts,
CUstomer is following article CS473270 to update "wt.manager.serialFilter" once this property is updated via xconfmanager -pf command windchill is unable to start with below error message
ERROR [main] wt.method.server.startup.services  - Failure to start manager wt.audit.StandardAuditService wt.services.ManagerException: Could not initialize Auditing service.
Nested exception is: wt.util.WTException: com.infoengine.exception.adapter.IEAdapterException; nested exception is:
javax.naming.NameNotFoundException: Entry does not exist: "o=ptc:ldapadmin@xc-s-zw02401.xc.abb.com/cn\=configuration,cn=windchill,o=ptc"
Nested exception is: com.infoengine.exception.adapter.IEAdapterException; nested exception is:
at com.infoengine.json.JSONAdapterImpl.processRequest(JSONAdapterImpl.java:144)
at com.infoengine.au.DirectoryService.executeQueryObjects(DirectoryService.java:260)
at com.infoengine.au.DirectoryService.queryObjects(DirectoryService.java:205)
at wt.federation.PrincipalManager.DirContext.getAdapterInfoMaps(DirContext.java:445)
at wt.federation.PrincipalManager.DirContext.initMapsForDefaultAdapters(DirContext.java:351)
at wt.federation.PrincipalManager.DirContext.init(DirContext.java:327)
at wt.federation.PrincipalManager.DirContext.getPrimaryName(DirContext.java:777)
at wt.org.StandardOrganizationServicesManager.getIdpServices(StandardOrganizationServicesManager.java:21913)
at wt.org.StandardOrganizationServicesManager.getDirectoryContextProvider(StandardOrganizationServicesManager.java:22113)
at wt.org.StandardOrganizationServicesManager.getUser(StandardOrganizationServicesManager.java:3920)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:569)
at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399)
at jdk.proxy2/jdk.proxy2.$Proxy84.getUser(Unknown Source)
at wt.org.OrganizationServicesHelper.getAdministrator(OrganizationServicesHelper.java:1382)
at wt.org.StandardOrganizationServicesManager.getDefaultAdministratorUser(StandardOrganizationServicesManager.java:21981)
at jdk.proxy2/jdk.proxy2.$Proxy84.getDefaultAdministratorUser(Unknown Source)
at wt.session.StandardSessionManager.getAdministrator(StandardSessionManager.java:324)
at wt.session.StandardSessionManager.setAdministrator(StandardSessionManager.java:288)
at jdk.proxy2/jdk.proxy2.$Proxy68.setAdministrator(Unknown Source)
at wt.audit.StandardAuditService.performStartupProcess(StandardAuditService.java:295)
at wt.services.StandardManager.startup(StandardManager.java:460)
at wt.services.ManagerImplementation.startup(ManagerImplementation.java:363)
at wt.services.DefaultStartupHandler.startup(DefaultStartupHandler.java:112)
at wt.services.StandardManagerService.performStartupProcess(StandardManagerService.java:168)
at wt.services.StandardServicesHandler.start(StandardServicesHandler.java:44)
at wt.method.MethodServerMain.run(MethodServerMain.java:589)
at wt.method.MethodServerMain.main(MethodServerMain.java:358)
Caused by: javax.naming.NameNotFoundException: Entry does not exist: "o=ptc:ldapadmin@xc-s-zw02401.xc.abb.com/cn\=configuration,cn=windchill,o=ptc"
at com.infoengine.au.json.parser.IEJSONParserHelper.checkDnExist(IEJSONParserHelper.java:412)
at com.infoengine.au.json.parser.IEJSONParserHelper.getObjectFromMap(IEJSONParserHelper.java:388)
at com.infoengine.json.QueryObjects.getSubTree(QueryObjects.java:307)
at com.infoengine.json.QueryObjects.getBaseDataBasedOnScope(QueryObjects.java:287)
at com.infoengine.json.QueryObjects.fetchQueryResult(QueryObjects.java:225)
at com.infoengine.json.QueryObjects.run(QueryObjects.java:176)
at com.infoengine.json.JSONAdapterImpl.processRequest(JSONAdapterImpl.java:114)
I have reviewed below files and it looks good to me
  1. wt.properties
  2. ie.properties
  3. ieStruct.properties
  4. IEConf folder
Also, reviewed articles
However entries are correct
When customer restore backup files which was taken before execting the command windchill starts without any issues.
  • Enabled below loggers to check is there any issue with the files, however it is talking about the ieStruct and ie.properties file
  1. logger.federation.name=wt.federation
           logger.federation.level=ALL
  1. logger.infoengine.name=com.infoengine
           logger.infoengine.level=ALL
Attaching below files for reference
  1. wt.properties
  2. ie.properties
  4. mapcredentials.txt
  5. methodServer logs
  6. site.xconf
Let me know if any additional files are required.
Ajay N.
