9-Granite
May 29, 2024
Cannot connect to license server after change of network
We recently changed the network in our organisation. The server holding licences for creo didn't change, it just change network.
Although the server is up and we can ping it, people can't access their licenses. Here is the creo error message and the result of ptcstatus.bat on the user side.
And here is the result of ptcstatus.bat on the server side :
VladimirNAnswer
Article - "Flexnet licensing errors observed when checking license server status (LMADMIN) using ptcstatus.bat for PTC Flex-enabled applications": https://www.ptc.com/en/support/article/CS402152
VladimirN24-Ruby IVAnswer
MatthewV9-GraniteAuthor
9-Granite
June 11, 2024
Turns out it was because my network was classified as public and not private so the exception rules for port 7788 didn't apply. The troubleshooting tool solved it.
Did the host IP address change? You may need a new license file.
9-Granite
May 29, 2024
Yes the IP changed but not the mac address (physical). I have run the Guided Licensing & Installation Troubleshooter from PTC referred by @VladimirN without success (I haven't done the uninstall reinstall process yet thow).
We managed to borrow licences running parametric_borrow.bat but we can't return them when running inside repertory "C:\Program Files\PTC\Creo 7.0.7.0\Common Files\x86e_win64\obj"
lmutil lmborrow -return -c "7788@192.168.1.128" PROE_DesignEss
 the error returned is :
We will work with those borrowed license until our deadline and try reinstalling License management application on the server.
You will need to get a new license as the one you show is tied to an IP address of 192.168.1.128.
Community Moderator
June 5, 2024
Hello @MatthewV,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
