9-Granite
May 29, 2024 6:53 AM UTC
Cannot connect to license server after change of network
We recently changed the network in our organisation. The server holding licences for creo didn't change, it just change network.
Although the server is up and we can ping it, people can't access their licenses. Here is the creo error message and the result of ptcstatus.bat on the user side.
And here is the result of ptcstatus.bat on the server side :
VladimirNAnswer
May 29, 2024 7:49 AM UTC
Article - "Flexnet licensing errors observed when checking license server status (LMADMIN) using ptcstatus.bat for PTC Flex-enabled applications": https://www.ptc.com/en/support/article/CS402152
VladimirN24-Ruby IVAnswer
MatthewV9-GraniteAuthor
9-Granite
Jun 11, 2024 11:59 AM UTC
Turns out it was because my network was classified as public and not private so the exception rules for port 7788 didn't apply. The troubleshooting tool solved it.
May 29, 2024 1:39 PM UTC
Did the host IP address change? You may need a new license file.
9-Granite
May 29, 2024 3:41 PM UTC
Yes the IP changed but not the mac address (physical). I have run the Guided Licensing & Installation Troubleshooter from PTC referred by @VladimirN without success (I haven't done the uninstall reinstall process yet thow).
We managed to borrow licences running parametric_borrow.bat but we can't return them when running inside repertory "C:\Program Files\PTC\Creo 7.0.7.0\Common Files\x86e_win64\obj"
lmutil lmborrow -return -c "7788@192.168.1.128" PROE_DesignEss
 the error returned is :
We will work with those borrowed license until our deadline and try reinstalling License management application on the server.
May 29, 2024 4:08 PM UTC
You will need to get a new license as the one you show is tied to an IP address of 192.168.1.128.
Emeritus
Jun 5, 2024 10:39 AM UTC
Hello @MatthewV,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
