18-Opal
Jun 24, 2014 8:08 PM UTC
Config Option to change Assembly Window Default
When Assembling a Component, it can be shown in the assembly context, in a separate window or both. Is there a config option to control this?
jbrouchAnswer
Jun 25, 2014 2:38 PM UTC
Take another look at "comp_assemble_start". The option: "constrain_in_window" will have your new component in that little secondary/imbedded window - all the other options will put new component in main window doing different things. All options will still give you toggle control while placing.
Mahesh_Sharma
22-Sapphire I
Jun 24, 2014 8:32 PM UTC
Joseph,
I think you are looking for config option accessory_window_display.
jwagh18-OpalAuthor
18-Opal
Jun 24, 2014 8:34 PM UTC
Mahesh,
I believe that option brings up a completely new ProE window for the component - which isn't what I need. I am looking for an option to toggle those 2 buttons at the top-right of the model window, when assembling a component, that toggle the component within the context of the assy or a separate embedded window.
Mahesh_Sharma
22-Sapphire I
Jun 24, 2014 8:46 PM UTC
Joseph,
Possibly, config option comp_assemble_start will help you
jbrouch1-VisitorAnswer
jwagh18-OpalAuthor
18-Opal
Jun 25, 2014 3:13 PM UTC
Bingo... good enough! Thanks!
