Configuration in Manufacturing
Community members... I'm making a cavity and every time I make the part it comes standard with "Units"=millimeter Newton Second (mmNs) AND Precision = Absolute 0.01. I would like to create a different measurement standard. As I am in Brazil, we use millimeters and the precision would like it to be Relative 0.0012. What configuration should I use? Thank you very much!
Creo 10.0.3.0
Translated by the Community Moderation using Google Translate
Membros da comunidade... Estou fazendo uma cavidade e toda vez que faço a peça ela vem padrão com "Unidades"=milímetro Newton Segundo (mmNs) E Precisão = Absoluto 0,01. Eu gostaria de criar um padrão de medição diferente. Como estou no Brasil, usamos milímetros e a precisão gostaria que fosse Relativa 0,0012. Qual configuração devo usar? Muito Obrigado!
Creo 10,0.3.0
mmelloAnswer
Hi KenFarley... what's up?
Thank you very much for your help. I also usually leave everything out of Creo default... I leave it in a folder and then point Creo to start in that folder.
I did the tests with the settings you provided and it worked correctly!!!! Thank you very much for your help!
tbraxton
As of Creo 7 relative accuracy is not an option when creating new parts, only absolute accuracy is available. If you have old parts with relative accuracy set, Creo will open them, but I strongly advise against using relative accuracy for anything going to production.
You should not be using relative accuracy ever for any manufacturing model in Creo or Pro/E even prior to Creo 7.
Article - CS332639 - Why default accuracy has been changed from relative accuracy to absolute accuracy in Creo Parametric 7.0 (ptc.com)
KenFarley
I totally agree with this. I've got models that are from Pro/ENGINEER with bloody relative accuracy and if I'm ever unfortunate enough to have to use them in manufacturing, I have lots of problems. Sometimes the manufacturing module will refuse to do anything with them, will not run simulations, etc. Other times, particularly with complex surfaces, I will get the "plunge to infinity" error when the cutter passes over a particularly bad surface-to-surface interface. And sometimes, just to make things even more interesting, toolpaths will work, but then if I change any of the stepover parameters or anything that changes the space between passes, it will fail. It won't tell me why it failed, but from experience the first thing I always suspect is the model is in relative accuracy.
The trouble is, it's a simple thing to set up a mapkey that I press and it changes the accuracy to an absolute value. I have this and it's great, but in some cases, like the aforementioned complex curvature parts, this can cause the model to fail. It's particularly nasty with models that have complex intersecting rounds, because the accuracy improvement results in a new topographical arrangement and number of surfaces.
Additionally, try to make sure all the models in your manufacturing assembly have the same accuracy, and your manufacturing assembly itself is the same as the models.
If you're using start parts that have been around since the old days, replace them with new models that have the proper accuracy settings. That way, at least with newly created parts, you won't have these troubles.
