2-Explorer
Mar 16, 2020 5:29 PM UTC
Creo 6.0 license and use for Creo 3.0 installation
Hello Everyone
We have Creo 6.0 license for learning purpose (not commercial usage). With this license , can't we use Creo 3.0 ? I am sure that our purpose is for learning and not for commercial purpose.
Any point or explanation would be of great help.
Thanks and Regards
Ketan
Mar 16, 2020 6:34 PM UTC
Why not just learn Creo 6!
Creo 3 is at least 5 years old.
There may be a limitation of how long the trial software is valid for.
You cannot mix commercial and trail software files.
Mar 17, 2020 7:57 AM UTC
if you have license file containing Creo 6.0 license, then you can select it during Creo 3.0 installation. Installer creates parametric.psf file referencing license file ... and Creo 3.0 will start seamlessly.
Mar 18, 2020 5:48 PM UTC
@Ketan_Lalcheta License files are backward compatible. If you have license file for latest version, the same license file can be used for older version of the application. However if you have academic/student license (learning purpose) then the same can not be used for commercial purpose. That  means if you create files using Learning license, you can not open them in commercial licensed Creo.
