Creo 8.0.3 stopped functioning & will not reinstall
Creo 8.0.3 stopped functioning a few days ago. Nothing happens when the executable is run, either by clicking on it or running via command prompt. I was able to uninstall Creo, but the installation executable also will not run. Nothing happens in either case, no error messages or warnings. This is on a Surface Studio, with an Nvidia RTXA2000 running Win11.
    OK, solved this by reinstalling 8.0.0 from the ground up starting with the Flex server.
    Copying in the program directory from 8.0.3 on a Win 10 virtual machine appears to work with some quirkiness.  Something with the DLL files doesn't play well with Win11 and the Flex server on 8.0.3 (I am guessing anyway).  Even after stepping back to version 8.0.0 the 8.03 setup.exe file won't run.
    Didn't want to step back to Win10, there are some workflows in Win11 Pro that I like.
    Staying on Creo8.0.0 for now.
    Probably also worth noting that other PTC products are running, like schematics or Mathcad.  No other programs on the laptop appear to have functional issues in the same timeframe.
    If you did not uninstall, you could try a configuration option graphics win32_gdi
    2.)
    You must unzip installation zip file into new empty directory, eg. C:\PTC\CR8
    Path to setup.exe must not contain spaces and national characters.
    3.)
    Check Event Viewer records for errors related to xtop.exe, parametric.exe, setup.exe
    Thank you Martin.
    1. - Unfortunately, I already uninstalled and can not reinstall successfully.
    2. - Confirm that I have done this.  Also worth noting that I successfully installed this Creo version 2 months ago and have used the program with no issues until a couple days ago.
    3 - Event viewer does show an application error with setup.exe.  baselibmt.dll has a fault.  Looking back to earlier this evening, the same module appeared to be causing issue with pim_re.exe when starting Creo.  A snippet of the application error below.
    Description:
    Faulting application name: setup.exe_Creo, version: 36.0.2021.403, time stamp: 0x61a0bcb2
    Faulting module name: baselibmt.dll, version: 36.0.2021.403, time stamp: 0x61a08565
    unfortunately Windows 11 is not supported OS at the moment, therefore you cannot ask PTC Support to resolve your problem ...
    My last idea ... install Creo on different computer and copy installation directory to your computer. Then you can test option no.1.
    WeirdWasatch1-VisitorAuthorAnswer
    Hello @WeirdWasatch
    Thanks a lot to have shared your "path to resoluion". As a general rulke, when copy-paste of install folder is useless, it's always good to try a "fresh installation from scratch" on the impacted machine.
    Replying also to you here, in order to share another information which will be probably interesting for you. We just learned this morning in PTC TS that Creo Hardware Notes is planned to be updated later today to reflect Windows 11 support for Creo 7.0.7.0 & Creo 8.0.3.0 and higher. Not an official info in this community, but sharing this information in advance anyway for your awareness.
    Serge
