Creo Elements/Pro 5.0 couldn't run on Win 10
Creo Elements/Pro 5.0 I was install this on both Win 7 and Win 10, software could run on Win 7 properly, but when I tried to run on Win 10, I always got the information below.
"Creo Elements/Pro configuration file open error"
ERROR: Unable to launch Creo Elements/Pro 5.0 because no valid configuration (*.psf) files were found. please run "ptcsetup" from your installation "bin" directory and create a PTC Startup File. This is needed for Creo Elements/Pro to launch successfully.
I also already tried many times to run the ptcsetup as error message, but still got the same error.
So I guess the Creo Elements/Pro 5.0 couldn't run properly on Win 10, is this correct?
If so, what version of Creo can work on Win 10 surely? could those file which created from Creo Elements/Pro 5.0 migrate to this new version? how much of the new version?
Thanks!
I would recommend you to copy psf file from Windows 7 installation.
MH
StephenW
If you've installed Windows 10 creator, it's likely you'll need to uninstall that update.
Older files can always be opened by the newer software.
You'll need to contact PTC or a reseller (VAR) to get cost information.
Below is a link about Windows 10 issues with the Creators update.
Re: Bluescreen after installing newest Win10-Update
Is Creo Elements/ProE 5.0 even supported on Windows 10?
I am thinking only Creo 2.0 M190+, Creo 3.0 M060+ and Creo 4.0 are Windows 10 compliant.
Mahesh_Sharma
22-Sapphire I
May 9, 2017
Angus,
Creo Elements/Pro 5.0 is not supported on Windows 10. But as per error you mentioned, application if unable to start due to missing startup file (.psf). This file remains in bin folder under installation directory.
You may try re configuring Creo Elemets/Pro 5.0 by executing ptcsetup.bat (RMB > Run as Admin) available under <installation Dir>\Bin.
alin-51-VisitorAuthor
so now Creo Elements/Pro 5.0 is "officially" not support Win10?
if this answer is correct, then I can have the reason to ask company for purchase the new version and give to me
MH
It's work! unbelievable! it was failed many time before, but it;s now resolved by your simple recommend.
Now it's comes new issues when using Creo Elements/Pro 5.0.
1.It must run as administrator, otherwise the Creo Elements/Pro 5.0 won't be able to write in c:\windows
2.The middle scroll of mouse not functional in Creo Elements/Pro 5.0, couldn't shrinking or zooming by middle scroll.
But it's fine, I already got the answer I need, thanks!
The correct answer is your!
1.] c:\windows is not usual ProE/Creo working directory isn't it ?
2.] try https://community.ptc.com/t5/System-Administration/How-to-make-scroll-wheel-zoom-work-in-Windows-10-with-Creo/td-p/412169#412857
MH
