Creo Icons
Can I make a simple to implement suggestion (and it is simple) relating to application icons?
Currently when you install Creo the icons for all versions are identical (so the Creo 5 icon is the same as Creo 6 etc). If you have multiple versions installed this can - and does - lead to simple errors opening the wrong version and occasionally results in files being updated to the new version.
A very simple solution - which SolidWorks and other use - is to add the version to the Icon. So rather than just a simple box with a blue box, have a box with 6 in it, or 5 -you get the idea. Maybe even change the colours as well?
Or just change the icons between versions. Anything is better than the current confusion.
Mahesh_Sharma
22-Sapphire I
@KQD
Suggestions for change in application can post in Ideas section for Creo..
https://community.ptc.com/t5/Creo-Parametric-Ideas/idb-p/creoparametric
KQD1-VisitorAuthor
Thanks have done that now.
Dale_Rosema
please do not expect that PTC will fulfill your request. Simply do it by your self and upload your icons to make other users happy 🙂
KQD1-VisitorAuthor
True, I could do it, but seeing as how we pay PTC every year for subscription services I really think this is one they should do. In my (long) experience of CAD vendors, if you don't tell them something is wrong from a UX point of view they assume all is well. But there is a balance to be had in suggesting major structural changes (like multi body part modelling) and things that will take their icon designer 2 mins. I'm suggesting this is in that latter category 🙂
This is a very important request, which already exists in almost all software
