Custom folder for parametric.psf
Hi there,
in Creo's bin folder (e.g. C:\Program Files\PTC\Creo 10.0.2.0\Parametric\bin ) there is a "parametric.bat", which executes
@echo off
"C:\Program Files\PTC\Creo 10.0.2.0\Parametric\bin\parametric.exe" "C:\Program Files\PTC\Creo 10.0.2.0\Parametric\bin\parametric.psf" %*
Is it possible to place that batch file and the corresponding "parametric.psf" anywhere else?
e.g.
C:\temp\%username%\custom-parametric.bat with
@echo off
"C:\Program Files\PTC\Creo 10.0.2.0\Parametric\bin\parametric.exe" "C:\temp\%username%\custom-parametric.psf" %*
I tried it, but it did not worked so far.
MatAnswer
I think I have it.
Instead of altering parametric.psf every time, I remove every "feature" in parametric.psf once and alter those settings via the "set" command by my start script.
set PRO_LANG=frensh
set CREOPMA_FEATURE_NAME=PROE_DesignEss (10119 10113)
set PTC_D_LICENSE_FILE=7788@my_license-server.com
<loadpoint>\Parametric\bin\parametric.bat
@Mat wrote:
Hi there,
@echo off
e.g.
@echo off
my suggestion ... do not play with OOTB location of psf files. I am almost sure PTC does not support different location of these files.
Maybe you can explain what do you need to achieve and why.
Mat16-PearlAuthor
Hi Martin,
the parametric.psf contains e.g. language settings, license type and server, special configurations like CEF_DEBUG_PORT and so on.
I wrote a small Dialog, where Users can choose their desired license. They also can define settings like language in their own "user-config.psf".
Mandatory settings like the license server address are stored in a company configuration file.
When the user clicks on "START CREO", all important config files get combined to "C:\Program Files\PTC\Creo 10.0.2.0\Parametric\bin\parametric.psf".
But unfortunately this requires write access to that folder "C:\Program Files\PTC\Creo 10.0.2.0\Parametric\bin\", which is not always granted.
Mat16-PearlAuthorAnswer
I think I have it.
set PRO_LANG=frensh
