custom map key file load / custom map keys stopped working
I am using Creo Parametric Release 11.0 and Datecode11.0.0.0
custom map keys not working after new creo install. creo_parametric_customization.ui file did not change.
start up load directory the same.
Mapkeys are moved to mapkey.pro file from your config.pro file the first time you run Creo 11.
When you start Creo 11, you get a warning that mapkeys have been moved to mapkey.pro and are NOT loaded from your local config.pro anymore.
tbraxton
Read these threads: Creo11 and Mapkey.pro - PTC Community
If you use any mapkeys that call other mapkeys on the fly: Mapkey toggle scheme no longer works in Creo 11+ - PTC Community
bmclees5-Regular MemberAuthor
Thank you for the information.
In the future when installing new versions of Creo Parametric how do you keep the mapkeys.pro file? Will this be saved or deleted?
Q: Will this be saved or deleted?
A: I don't have a definite answer. It's always a good idea to make a backup.
