Drawing templates: Historic up-issue
I've seen, maybe with other CAD packages, a way that the drawings keep a log of historic up-issue's. How does everyone manage that here? At the moment I'm creating new drawings, saving it with a different file name and only including the modification that required the up-issue for that one drawing. Ideally I'd like to keep a log of the modifications from initial drawing through to the current iteration.
I hope that makes sense?
What's an up-issue? I'm not familiar with that term.
Hi Dave,
It's an increment of an issue number on a drawing. Maybe slang that I've gotten used to using!
I don't know what an issue number is... that might be a process or terminology specific to an industry or companies I haven't worked for.
Is that like a revision number?
joe_morton
Are you using Windchill to manage your files? Windchill keeps the history of the drawing, so there's no need to change the filename. We keep a manual table on ours for the engineer to enter information on what changed in that particular revision
No I'm not using Windchill.
It was that table that I was trying to find an automated method of updating after each change. I'm guessing it's a manual process.
Chris3
Currently there is no way to automate this. There is a Creo enhancement idea for this for those that use Windchill:
https://community.ptc.com/t5/Windchill-Ideas/Add-Windchill-parameters-for-latest-change-number-and-where-used/idi-p/470362
Solidworks has a solution for this with their PDM package. There is a link in the Creo idea that shows how it is done.
We have given up on this and we now just have a statement that says to review the history in PDM.
