GC
  • February 25, 2011
  • 13 replies
  • 2548 views
Pro E users,
Any suggestions on a medium range graphics card for WF 5. (windows 7)
Brad
P Please consider your environmental responsibility before printing
this e-mail.
    I am having a problem with the Quadro 2000 (Windows 7 64 bit on a Dell T7500). When I first open up a model then the screen is black until I rotate it. Also sometime the buttons are greyed out for some menu picks. However, it is my own fault as it is not listed as supported:
    http://www.ptc.com/WCMS/files/60077/en/dell_wf4.pdf
    In Reply to Paul Korenkiewicz:
    http://www.nvidia.com/page/quadrofx_family.html
    Nvidia Quadro's... They list midrange as the 2000 model...
    Thanks...
    Paul Korenkiewicz
    FEV, Inc.
    4554 Glenmeade
    Auburn Hills, MI., 48326
    I also have a black screen upon model load until rotation.
    FYI, I am using WF50 M060 on a Dell T5500 using Windows 7-64 bit and a
    Quadro 3800 card.
    I'm running video card bios 62.0.74.0.b and driver 8.17.12.5981
    So, I don't think all of the fault is your card (hardware). There is no
    Pro-E setting specifically for the card. I am using '3D App - Default
    Global Settings' in the NVIDIA Control Panel.
    Christopher F. Gosnell
    FPD Company
    124 Hidden Valley Road
    McMurray, PA 15317
    I hear a lot of issues with Quadro cards on Dell machines with Windows 7
    64 bit.  I'm running the 3800 and have the black screen issue
    occasionally, but not often.  I also have occasional graphics card
    crashes, which others have reported, flashing and ghosting when dragging
    the insert bar in the model tree and model flashing when resizing the
    model tree.
    Not sure if this is a Dell issue, an Nvidia issue, a 64 bit issue or a
    Pro/E issue.
    Doug Schaefer
    I get the same 20% of the time
    Dell T3500
    Quadro FX 1800
    WF5 M020 & M060
    W7 64 Bit
    bios 62.94.96.0.6
    Driver 8.15.11.9038
    Gary Pitt
    Columbia Plastics Ltd
    Surrey, B.C. V3S 8E5
    Canada.
    604 530 9990 ext 236
    e-mail garyp@columbiaplastics.com
    This may not be pertinent in this case.
    I built up a system for analysis. I chose the Nvidia GTX480 because of the
    480 GPUs in it for some fea and cfd. It has 1.5g of ddr5 ram. I am running
    Win7-64 with 12G ddr3. The first build had a noname ssd and a XFX mainboard
    and graphics card. I figured that the same vendor could make their things
    run well together. The ssd kept hiccupping, so it got replaced with an Intel
    ssd. Nothing but problems with the XFX. Dumped them and put in a Gigabyte
    mainboard and a Gigabyte GTX480. All runs well for almost a year now.
    Quality components made the difference. Just because it says Nvidia Quadro
    2000 doesn't mean there aren't any differences in vendors.
    Good luck,
    Bill
    I'll add mine to the mix... I think it is a Win7 x64 bug...
    I am running a Lenovo W510 w/ nVidia Quado FX880M Win7 x64 and I get the
    black screen probably 20% of the time as well.
    -Nate
    8-Gravel
    February 28, 2011
    I am experiencing the same issues with a Dell M6500 Windows7 64 bit with
    a Quadro FX 3800 M.
    Okay - It must be a WIN7 64 bug, as I am using a Dell M6500 with an Nvidia
    Quadro and am having NO graphics issues
    Anthony R. Benitez
    Senior Mechanical Designer
    Drafting Supervisor
    Applied Research Laboratories
    The University of Texas at Austin
    I'm seeing the same problems with Win7 32 bit, NVIDIA Quadro FX 1800M, Dell M4500.
    Chris Weiler
    Independent Contractor, Mechanical Design Services
    Goffstown, NH
