Feb 25, 2011 10:09 PM UTC
GC
Pro E users,
Any suggestions on a medium range graphics card for WF 5. (windows 7)
Brad
P Please consider your environmental responsibility before printing
this e-mail.
    Feb 28, 2011 10:03 PM UTC
    Forgot to say - WIN XP 64
    Anthony R. Benitez
    Senior Mechanical Designer
    Drafting Supervisor
    Applied Research Laboratories
    The University of Texas at Austin
    Feb 28, 2011 10:23 PM UTC
    My guess is it is the cut of the driver. I do not have this problem. I have a Dell laptop M6400 Win7 64Ultimate with a Quadro FX 2700. My driver is from the Sept-Oct 2010 time frame. I will look up the actual numbers but I have not had a need to update the driver, because it works. Also a co-worker has been evaluating a dell and he has not spoken of a problem, his driver is very old. His driver is dated 12/16/2009 version 8.16.11.8843 running a FX3500M
    I would try an older driver.
    Ron
    Mar 1, 2011 3:19 PM UTC
    I've got a Dell T3500 with Win7 Ultimate and Quadro 2000. I had no problems at first, then I added a second monitor. After that I started getting Pro/E black screens, also had problems with dialog boxes for family table instances and simplified reps not showing up. I poked around and found the nView had been turned on during the second monitor configuration. I turned nView off and everything is working fine once again. I've had problems on previous computers with nView affecting Pro/E so I strongly recommend you turn it off.
