2-Explorer
Nov 5, 2013 3:08 PM UTC
Import Data Doctor - Commands Greyed Out
I am trying to get to grips with IDD in WF4.
I went to Tutorials in the Help Collection and followed the 'Getting Started with Import Data Doctor' link.
There are some files that come with Pro/E, with the appropriate problems embedded in them.
I worked my way through to the part where it says:
After you have determined where the gaps are, by either finding them with the Search Tool or defining them manually, use the following procedure to add wireframe edges to repair them. When you add edges to the wireframe model, and click
Close the Gaps
Repair
, the defined wireframe gaps are closed.
1.Click on the Repair Tools toolbar or
Edit > Add to Wireframe
2.Click on the Repair Tools toolbar. The Repair dashboard appears. The surfaces that are being repaired are highlighted in the graphics window.
3.Click . The gaps are closed.
The icons shown in the tutorial are greyed out.
IDD is shown as a menu item in the top row of menus.
The IDD icon group shows up when I click the little first aid box icon.
I can't do anything with the IDD icons, because they are grey.
System Information shows IDD is an installed option.
I have asked PTC support and they have looked at my licensing and confirmed that it is OK.
It still doesn't work.
Any ideas why this could be?
John
WF4, M220
JWaymanAnswer
2-Explorer
Nov 5, 2013 5:08 PM UTC
It's fixed.
It all comes down to:
RTFM
I was following the tutorila that comes with Pro/E, using the files that come with the tutorial. The firt step is to fix the 'coincident suface' problem. I could see how to do that, it seemed relatively trivial, so I moved on to the more interesting gap filling part.
No! You can't do that.
Until I had removed that coincident surface (on another area of the part altogether) I was not able to fill the gaps.
It's probably logical deep down, but I've lost the will to find out just now...
John
Nov 5, 2013 3:18 PM UTC
Hi John
Can you provide a screen grab to show the greyed out icons etc.
Did you find the gaps using the Search Tool or identifying them manually?
JWayman2-ExplorerAuthor
2-Explorer
Nov 5, 2013 3:39 PM UTC
Charlotte,
I identified the gaps using the Search Tool. They lit up in red OK, but I was unable to do anything with them.
Cheers,
John
JWayman2-ExplorerAuthorAnswer
2-Explorer
It's fixed.
RTFM
John
