Jan 16, 2013 6:37 AM UTC
Insufficient Constraint Problem
- 2 replies
- 1997 views
- Translate All
I am trying to model a shaft-like part in torsion (Tripod CV Joint). I've been getting messages telling me some elements are insufficiently constrained, so I tried a simple modal analysis to verify my constraints. No matter how many surfaces are constrained on the model, however, I always get the same message that one or two elements are insufficiently constrained, which really doesn't make sense to me. The problem elements usually have either a node on a surface or a corner.
Has anyone had similar problems?
I have attached the file in question, but it has been created using a university license so there might be incompatibility with professional licenses.
Thanks!
