Apr 8, 2014 7:19 AM UTC
Layer status for family table instances
Hi all,
is it possible to control the layer status of individual family table instances? Lets say i have a layer named A. I want this layer visible on my generic model, but turned off, on some, but not all, of my instances. I have been trying this, but it appears that whatever layer status you have for the generic is passed to all instances, this is a shame. I am hoping that i am missing something, that perhaps there is a config option, a setting, something that could help me achieve my goal.
John
Apr 8, 2014 7:29 AM UTC
its a real good idea to have layer status in family table variation, but i guess u need to give the idea. However I am also looking for some alternative ways if someone can suggest.
2-Explorer
Apr 8, 2014 1:00 PM UTC
What is your goal?
Apr 8, 2014 1:09 PM UTC
Hello, my goal? To be able to do as i describe. I would like to be able to control the layer status of individual instances within a family table.
John
2-Explorer
Apr 8, 2014 1:54 PM UTC
OK. I thought you had some reason for wanting to control the layers, rather than controlling the layers being an end in itself.
You might be able to control the display you want by creating separate layers for the items you want controlled separately.
Of course the reason it doesn't work now is that PTC doesn't have that capability written into the software.
The way it works now is that each layer is a list of items and layer visibility is controlled by a list of the status. To make each instance independent would add another list to each instance, which would be a list of the list statuses. But that is unlikely to happen.
For example - suppose you have two instances. One with an axis you want displayed and one you don't. It's the same axis on the same layer. Now, put them both in an assembly. How is the software to both display and not display the same axis based on the same layer being on and off at the same time? It would add another level of indirection to every item being displayed, slowing every display operation to check each part's layer status list-list.
Think about how would that would appear in managing layers at the drawing. Would each layer then be prefixed by the name of the part controlling the layer to allow each layer it's own part-dependent status?
