Jun 30, 2016 4:30 PM UTC
License management for Creo Elements Direct Modeling
Hi everyone,
If the CAD end-user ran two Creo Elements Direct Modelings in one PC, is it used two licenses?
Jul 15, 2016 11:22 AM UTC
What you describe is "as implemented".
*one* Modeling License actually is a "bündle" of *two* licenses, which allows you to run/open  *two* executables on the same machine.
This implements "Modeling includes Drafting", or in other words, you buy 1 x product Modeling and you can run Modeling *plus* Drafting on the same machine,
but *not* on two different machines.
As soon as you start Modeling, the License Server reserves the "bündle of two" licenses for your Computer.
When you start the second Modeling, the License Server gives the "second half" of the license bündle to the second Modeling.
This explains why you see the "license Count = 2" when you start the first and the second Modeling.
When you start a third Modeling, you will pull the next "half of a bündle" from the License Server.
This is why the license usage jumps to 4.
Please note that the ability to start 2 Modeling executables with *one* license bündle is actually an implementation error.
Legally, you are allowed to run 1 Modeling +1 Drafting or 1 Modeling´+ Annotation with this license.
With product Model Manager, the "product" is similar:
"Model Manager includes Drawing Manager"
But with a Model Manager license,, you can only start *one* Model and *one* Drawing Manager,, but not two Model Managers.....
btw. I was the Mentor of Claus Brod.
      Max
Jul 3, 2016 10:59 AM UTC
can only describe my own situation safely.
I have my single license on a USB network adapter.
Can thus start 2x Modeling of  the same version or 2 different versions of Modeling or 1x Modeling and Drafting (drafting in the same version Several times) at the same time.
When I want to start drafting in different versions I have to stop Modeling.
I think that a lot of different scenarios are possible.
In any case, you can precisely define the use of licenses in the file licence.conf.
View the Help in the license directory.
Best regards
Friedhelm
hmaie1-VisitorAuthor
Jul 7, 2016 11:29 PM UTC
Dear Friedhelm,
Thank you for your response.
I can't find the license.conf in the license directory.
Is it because the license is managed in my company's license server?
Jul 8, 2016 1:36 PM UTC
Hi, yes this is possible,
as i wrote before
The best is to ask your Systemadministrator
Best regards
Jul 10, 2016 4:08 AM UTC
In addition to Friedhelm's response, it is good to know that Modeling takes one license, and activating Annotation takes a second license (just like starting Drafting takes a second license).
You may be able to see the license availability if you know the name or IP address of your company license server. Of course, as Friedhelm suggests, your system administrator could also be very helpful here.
Please let us know if you have any further questions.
Good luck!
andy
Andy Poulsen
AI MAXTools: Dream. Design. Done. It's That Easy!
Add-in products to make PTC® Creo® Elements/Direct®  and CoCreate® products even faster!
www.ai-maxtools.com
Jul 11, 2016 1:14 PM UTC
There are several ways to find out where your license server is running.
Open a Windows CMD window.
netstat > c:\Temp\net.txt
Then use a Editor (e.g. Notepad++) and look for '17171' in the file. Result (e.g.)
Line 18:   TCP    127.0.0.1:57570        mkublin-8760w:17171    ESTABLISHED
Then you know that the license server is located on machine mkublin-8760w  (in my example).
Next, use your browser to visit the Web Page of the license server, e.g.
http://mkublin-8760w:17171
For more info, read the license server Help (available through the Web Page above or directly from the Help of Modeling (SolidDesigner))
Hope this helps.
Jul 15, 2016 2:43 AM UTC
Thanks to your help, I have been able to get it.  It will be really helpful for me!!
To be honest, I had known this tool before I posted this topic.
I got this information from Claus's blog.  -> CoCreate Modeling FAQ: Licensing
(This Web site contains plenty of useful information!)
However, I couldn't find out name of the license server.
By the way, I did some experiments.
According to the experiments, it is used two Modeling licences, when I started one Direct Modeling application.(The licence usage became plus two.)
Then, when I started two Direct Modeling application, the licence usage is still plus 2.
When I started three Direct Modeling application, the licence usage became plus two again. (Four licences is used as total.)
Best regards,
