Mar 27, 2013 6:37 PM UTC
License monitoring
So what is everyone using now-a-days to monitor the licenses of Pro/E?
Steve G
Apr 2, 2013 4:50 PM UTC
We had our timeout set short some time ago, and it was a PITA - although mostly because our system seemed to have a habit of calling Pro/Crash an unspecified but short time after losing (and regaining) a licence. Having said that, it can also be really annoying when there aren't enough licences - stop to answer the phone for six minutes, and when you've finished you find you can't continue working on CAD.
In particular, I recall it being a nuisance at lunchtime because we share our licences globally, and sometimes you'd stop for lunch, then when you came back you'd find that the States had claimed all the licences and you couldn't do any work that afternoon.
I'm not sure what we currently have it set to (and at the moment I believe we have plenty of licences so it's less of an issue), but these are some things to consider.
HTH,
Jonathan
Apr 2, 2013 4:54 PM UTC
The minimum timeout is 20 minutes. You can't set it for less. That is what I have it set at. The default out of the box is 2 hours.
You will want this config option:
suppress_license_loss_dialog YES
Apr 2, 2013 5:26 PM UTC
I set timeout to 1200 (this mean 20 minutes). As I know this is the lowest possible for PTC software. This have been working without any issues for many years for +70 users. No complains from users and they did not have to close creo when they had to go to meetings. Another benefit is that no one are ableto block a license in the morning without using it.
No crash related to the timeout.
venlig hilsen
Johannes von Zastrow
Apr 3, 2013 12:48 PM UTC
I was just looking through the log file and noticed that license denials are logged. It would be pretty simple to write a script to extract that information from the file and create a report.
e.g.
14:13:43 (ptc_d) DENIED: "PROE_Flex3C" user@their_pc (Licensed number of users already reached. (-4,342))
Also I had forgotten about the "ptcreport.log" file which is also stored in the licensing folder: this file stays intact if the server is relaunched, so I would assume that it keeps a running total of license data. It is encrypted or in a non-readable binary format so I presume that the commercial tools read this file.
In Reply to alfonso medina:
That's pretty cool. I think denials are the No. 1 data you want if you need
to get more. You always get asked "well how many more?" Denial counting
gets you some clues as to how many more.
Actually while we are on this subject and since someone else mentioned
already... See we have this dumb idea that our ideal ratio is 2.9 users per
license. Well it seems to work for us, but then some guys from another
company gave us a presentation on some unrelated software and made mention
of the license settings. They say that if you set the time out to 5 minutes
or less, that your license availability becomes excellent, more than
doubling our current ratio.
That made sense to me because I know for example I can get busy or go to a
short meeting while using up a pro/e license that will stay with my
computer for half an hour. The other users will probably have similar
situations. Most of our engineers only go home to say hi to the kids and
see if the wife is still there. Otherwise they have their nose stuck in the
small crevices left open in what used to be walkable space in the labs. So
the little time they spend on pro/e, should be a blessing to the rest of us
cad monkeys who only know to extrude first and ask questions later. So does
setting that time out to 5 minutes work? Do you guys do this or similar at
your different companies?
Can we get a poll of how many minutes you guys have set your time out to. I
would be really interested, I think its always an eye opener when others do
things completely different and it works better.
Apr 4, 2013 2:08 PM UTC
A while back I started working on a license monitoring tool in my spare time (ha! what's that?). It is still an incomplete project, but I was working on a few regular expressions to pull out the relevant data from the log file and from an lmutil file. I cannot find the one for the log file at the moment, so it is probably burried deep in an old folder in a random text file, but here is the one I could find for the lmutil (what ptcstatus runs) file.
\b\w+?\b\s\b\w+?\b\s(?<license>\w+?)\:\s+?\(.+?(?<total>\d+)\s.+?;\s+?.+?(?<used>\d+)\s.+
This generates an array of structs containing the name of the license, total licenses available, and total in use. If you only want to look at one license (say, PROE_Flex3C), then add the first part of the name (enough to make it unique) between the closing angle bracket of license and the \w:
\b\w+?\b\s\b\w+?\b\s(?<license>PROE_Fl\w+?)\:\s+?\(.+?(?<total>\d+)\s.+?;\s+?.+?(?<used>\d+)\s.+
And here is the one I used for sorting individual user informations:
\s+(?<user>\w+)\s(?<computer>\S+\s)\S+\s\(.*\)\s\((?<server>\S+)\/(?<port>\d+)\s+(?<id>\d+).+start\s\w+\s(?<date_time>.+)
I'm just a mech. E. and I am still teaching myself how to write these. If someone else has a better reg. ex., I'd love to see it.
-Lawrence
STEVEG21-Topaz IAuthor
Apr 16, 2013 1:08 PM UTC
Thank you for all the responses. Since I do not know any of the pearl or sql, etc languages, andI doubt my company will spend the money for a license monitoring program,I will have to stick with my batch file I wrote to utilize the ptcstatus command. It doesn't get the license denial information but what we have is enough. Barely...
Steve Galayda
